How to center- late style XJS ZF steering rack?
Old Jan 17, 2019 | 12:46 AM
XJsc-guy's Avatar
Default How to center- late style XJS ZF steering rack?
Hi, I'm upgrading the rack in my 88 XJS to the later style 93-96 ZF unit. On the older racks, centering was done by removing the grease fitting on the adjuster assembly below the tower and inserting a 1/4" rod to land in a center depressed spot on rack itself. I can't seem to find a similar spot on ZF rack?? There is a rubber plug in the same general location as the grease fitting on the old units, but I can't detect any spot to mark center inside on rack itself.
Does anyone know?
Old Jan 17, 2019 | 02:43 AM
Greg in France's Avatar
On the ZF rack there is a small Allen headed grubscrew just to the side of the rack tower. Unscrew this using a 4mm allen key, and a pointer be inserted into a shallow indentation that can be felt as a helper slowly moves the steering.
Old Jan 17, 2019 | 11:55 PM
XJsc-guy's Avatar
Thanks- I'll check it out!!!
Old Jan 18, 2019 | 08:58 AM
Fla Steve's Avatar
My rack is leaking and I'd like to install the ZF rack as well. Please tell us how it feels vs the old when you get it installed.
Old Jan 18, 2019 | 09:06 AM
The ZF has more road feel and is slightly less assisted. You feel more directly in contact with the wheels than with the Adwest. It might be a tad higher geared, but it certainly makes the car more responsive-feeling to the steering.
reverendalc
Dec 20, 2018 02:03 PM
XJsc-guy
Oct 29, 2013 02:45 PM
chupacabra
Jul 16, 2010 04:53 AM
Jaggyx
Dec 20, 2009 05:30 PM
