How to determine if you have the 'Sport Package"?
Old Aug 22, 2014 | 03:53 PM
75Gremlin's Avatar
Default How to determine if you have the 'Sport Package"?
Does anyone know?
thanks
Old Aug 22, 2014 | 04:12 PM
ptjs1's Avatar
75gremlin,
It;s relatively to state what you SHOULD have depending on the engine size and year, if the car was specified as standard. The difficulty is that it was possible to order Sports suspension on a car that would normally have Touring suspension and vice versa. And because most cars may have had replacement springs, shocks and tyres since new, it becomes difficult to tell.
However, in simple terms, if you've got a big-bumpered car and you've got original green shock absorbers, you've got Sports suspension.
The definitive answer is to order a Heritage build certificate from Jaguar which will tell you.
Hope that helps.
Paul
Old Aug 22, 2014 | 05:23 PM
Mkii250's Avatar
Rear sway bar on a 93 would mean Sports Pack. My 1992 has the package and original the shocks are dark grey.
Old Aug 22, 2014 | 05:33 PM
ptjs1's Avatar
The green Bilsteins came in at big-bumper time, which is VIN 188105 end of April 1993.
I think Americans mean something different when they say "93". All cars built from May 1993 with Sports Suspension do not have a rear anti-roll bar as it was deleted from the above VIN changepoint.
Hope that helps
Paul
Old Aug 22, 2014 | 05:47 PM
75Gremlin's Avatar
The reason I ask is that my understanding is that the "Sport Pack" cars had improved steering bushings compared to the earlier models.
Old Aug 22, 2014 | 06:08 PM
ptjs1's Avatar
75gremlin,
The issue is that "Sportspack" means different things depending which year you're talking about. The later spec used a standardised steering rack bush setup.
IMO, the best rack improvement is to put £30 worth of 'urethane bushes in the rack. Transformed the handling for me and much more long-lived than original standard or the old sports bushes. Just my opinion.
Paul
Old Aug 22, 2014 | 06:20 PM
75Gremlin's Avatar
Thanks Paul!
Mine VIN is 187XXX so its an earlier 1993 and apparently I would not have the Sportspack.
I'll look into the urethane steering bushings once/if I get my brakes sorted out.
Cheerio
sadepol01
16
Nov 22, 2024 05:05 PM
trickeyM
Oct 4, 2015 05:43 PM
Nic1635
Oct 2, 2015 01:30 AM
ziondio
Sep 29, 2015 01:58 PM
