How do I get at the automatic box to change the fluid?
Old May 17, 2015 | 08:04 AM
1bolt left's Avatar
Default How do I get at the automatic box to change the fluid?
Can't see much under there as don't have a lift nor a pit. Does it get refilled from inside the cab or underneath?
TIA for any guidance.
(XJS V12 - no Model Year in forum user profile - GGG)
Old May 17, 2015 | 09:20 AM
Mikey's Avatar
You might want to add what kind of car you have and maybe post in the appropriate tech section.
Old May 17, 2015 | 09:41 AM
Welcome to the forum 1boltleft,
I've moved your question from General Tech Help to XJS forum. Members here with the same model will be able to help.
Old May 17, 2015 | 10:20 AM
Safari's Avatar
1989 XJS V12
In the engine bay, on the passenger side near the fire wall is the dip stick for the transmission fluid. You add fluid there.
If you want to replace the fluid and filter then you need to remove the transmission pan. There is no drain plug so the only way to remove the old fluid is to drop the pan.
Mark
Old May 27, 2015 | 04:41 PM
1bolt left's Avatar
Sorry, done now. 1989 XJS V12, HE, COUPE, SOLENT BLUE.
99xk8guy
Sep 29, 2025 10:51 PM
Wes Steenrod
Sep 6, 2015 06:52 PM
David Thompson
Sep 3, 2015 07:48 PM
pnwrs2000
Sep 3, 2015 11:55 AM
MC36
US Lower Atlantic
Sep 1, 2015 07:34 PM
