How to replace the alternator belt?
Old Jun 25, 2011 | 11:17 AM
bigwiki's Avatar
Default How to replace the alternator belt?
I have a 95 4.0L. I want to replace the alternator drive belt but looks like I have to remove the fan clutch in order to get the alternator drive belt out. Is that true?
Old Jun 26, 2011 | 04:44 AM
I doubt it very much.
Usual way is remove the belt from the pulleys, then simply 'wind it out around the fan". Replacement is the reverse. the fan will "spin" on the clutch assembly, so hook it around one of the blades, and wind the fan by hand and let it wind out. Of course "holding ones mouth at the correct angle" assists greatly.
My V12 was a challenge when I first got it, coz the fan on them is near impossible to remove with any sort of ease, but the belts all wound off and then back on simply.
Old Jun 26, 2011 | 03:20 PM
warrjon's Avatar
Grant is right you can do it that way, I did it that way last year.
However to remove the fan is 8 bolts I had radiator out a couple of weeks ago 4 bolts on the fan and 4 bolts on the shroud. I found it much quicker than trying to work around the fan. The later V12's use a different fan clutch hopefully the 4.0L uses the same clutch as it is reasonably easy to remove.
It would have to be the alt belt it is the last to come off.
Old Jun 27, 2011 | 03:37 AM
bigwiki's Avatar
Thanks for the info. I'll try workaround the fan first. I have never removed the fan clutch. not sure how difficult to remove the 4 fan clutch bolts. You know the fan keeps moving.
Old Jun 28, 2011 | 04:29 AM
warrjon's Avatar
The entire fan and clutch assembly is removed with 4 bolts on the idler pulley. It is pretty easy and you have to remove the fan shroud bolts to get the fan out.
Be very careful with the around the fan it is easy to bend radiator fins if the belt goes too far through and hits the radiator.
Forcedair1
Sep 8, 2025 01:57 PM
RoyLittle0
May 25, 2023 02:38 AM
cissdm
May 3, 2016 06:02 AM
Bowman
Sep 15, 2015 06:54 AM
KarimPA
Sep 3, 2015 07:32 PM
