How taught should throttle cable be?
Old May 4, 2014 | 11:28 PM
SeanPeterLynch's Avatar
Default How taught should throttle cable be?
Mine has a little play. Not very tight. Was wondering because kickdown switch doesnt seem to work when I floor it (esp over 40MPH). Not sure if its the switch, or just not fully extending the cable and causing the switch to trigger.
Any help welcomed.
Old May 5, 2014 | 01:03 AM
Doug's Avatar
Virtually zero slack.
As I recall the mounting for the kickdown switch is adjustable as well to help ensure the the level arm of the switch can come into solid contact with the actuating button-thingy on the throttle cable
Also check that the throttle pedal pivot inside the cabin has the bushings in place. If not, the result will be lost motion as the pivot point ***** to one side, and the pedal arm will not provide 'full pull' of the cable.
Old May 5, 2014 | 08:23 AM
1800doogie's Avatar
Default When?
Hey Doug, when you gonna get another XJS? You know its gonna happen!
Old May 5, 2014 | 08:31 AM
So I tried to tighten things up via adjusting where the kickdown bracket thing screws in. Made it a tad bit tighter, but still has a little more play than it should. Is there a way I can further adjust this (I think I've seen discussions in this forum saying you can adjust at pedal), or do I have a stretched out cable? Is there an adjust / tighten solution here?
Old May 5, 2014 | 08:57 AM
Doug's Avatar
I'm not aware of any cable adjustment other than the obvious one where the throttle cable attaches to the throttle pedestal.....that is, the two nuts at the end of the cable. If you can't take up the slack there then, yes, I'd say the cable was stretched.
Old May 5, 2014 | 09:00 AM
Doug's Avatar
We'll see. Maybe. One of these days. I dunno. :-)
I'd love another XJS at some point but my next project is a Ser III V12 sedan.
Old May 5, 2014 | 01:17 PM
sidescrollin's Avatar
there is a spec for it, put a very small feeler gauge on the stop and tighten up the slack so you know there is a gap, but its virtually nonexistent
jimforrest (uk)
Feb 28, 2019 06:42 PM
adam699
Oct 13, 2015 05:53 PM
tomkilner
Oct 9, 2015 07:10 AM
10 XF Premium
Oct 2, 2015 09:22 PM
inactualis
Oct 2, 2015 11:13 AM
