I have been Driving it all wrong???
Old Mar 7, 2014 | 08:38 PM
RonaldP's Avatar
Default I have been Driving it all wrong???
I was looking up some information in my "Drivers Handbook" only to find out I have been doing it all wrong... What is to follow is right out of my handbook page 55 section 4. (JJM 18 02 06/40)
"The selector lever may be left in "D", "3", "2" unless the vehicle is to be parked. If the vehicle is stopped for a traffic light or junctions, apply the park brake (handbrake) and move the selector lever to position "N". "
I take it our transmissions are to delicate to idle in gear???
Somebody stayed up all night thinking of that one.
Old Mar 7, 2014 | 09:40 PM
Ezrider's Avatar
i believe later xjs had the 4l60e and earlier a turbo 400 both transmissions can also be found in chevy full size pickups. they are a tough transmission. it is possible to heat up a auto transmission sitting in drive with your foot on the break but you would get tired of holding the break and slide it into park long before it was a issue.
Old Mar 7, 2014 | 10:26 PM
Jagfixer's Avatar
You'll find a lot of European cars , Land Rover for one, recommend this procedure when
n idling for more than 10 minutes. Really not necessary with the TH400 tranny. But engine does idle a little higher when in neutral for fluid cooling.
Old Mar 7, 2014 | 10:34 PM
AllanG's Avatar
It's got nothing to do with the robustness of the transmission, it's a safety issue. In England when you are learning to drive it is a requirement that when you come to a stop at a traffic light, you put the transmission in neutral and handbrake on. Failure to do so on your driving test meant failure. (Not sure if that is still the rule but was for me growing up)
The idea is that should your foot slip off the brake or you are shunted from behind, the car does not go careening off potentially causing more damage/injuries.
I still put my transmission in neutral every time I come to a red light, though I must say that I don't apply the handbrake unless I am parked. Old habits die hard I guess
Old Mar 7, 2014 | 10:40 PM
Steve8's Avatar
Taxi drivers in Hong Kong would do that in stop and go driving. With great enthusiasm, coupled with an equally enthusiastic leap forward for 10 feet before repeating. Used to drive me crazy! Figured it was the English influence in driver training, because I soon learned the rest of the population drove in the same way!
Old Mar 8, 2014 | 09:42 AM
Ezrider's Avatar
i think in America they would fail you on a driving test for doing that
Old Mar 8, 2014 | 03:48 PM
calvindoesntknow's Avatar
I used to do that on my corvette at every stop light, because it would slowly churp the rear tires because it has so much cam.
This is common with motors that take a long.time to warm up too, because it allows the high idle to stay as long as it needs to.
Forcedair1
Sep 8, 2025 01:57 PM
Raul Lara
Sep 14, 2015 07:31 PM
Xkr x100
Sep 6, 2015 08:50 AM
d a
Sep 3, 2015 02:34 AM
Raul Lara
Sep 2, 2015 05:23 PM
