idle speed setting
Old Feb 9, 2012 | 02:16 PM
93XJR-S's Avatar
Default idle speed setting
Does anyone know what the idle speed / rpm should be at idle, my vehicle is a 93' XJR-S with 6.0L V12. Currently is idles around 900-1,000 with AC on in park.
Thanks for any info. you can provide!!
Paul
Old Feb 10, 2012 | 01:52 AM
Japthug's Avatar
Hi. It should be between 750-850 at the normal temp. So it is a little bit higher. If the coolant temp is lower than middle, for it is winter now and it will be hard to warm up fully, it is normal.
Hope this helps
aholbro1
Dec 29, 2024 06:46 PM
Rivguy
Dec 4, 2020 07:55 AM
PMKimpton
Aug 3, 2019 08:22 PM
Thang Nguyen
Oct 12, 2015 01:25 AM
MC36
US Lower Atlantic
Sep 1, 2015 07:34 PM
