Ignition wire lengths and plug boots - Lucas
Old Sep 10, 2019 | 03:24 PM
Dukejag's Avatar
Default Ignition wire lengths and plug boots - Lucas
Can someone please confirm the cable length of the ignition wires and which ones have straight or 90deg plug boots.
Also if someone could add the lead name that would be great.
I am dealing with Power Spark UK – whom are making me some leads, they want to check the lengths and boot angles.
The following info is what they have on file, I would like to have the number the leads.
1988 V12 Lucas Ignition.
Cable Length 1 (mm) 150
Cable Length 2 (mm) 190
Cable Length 3 (mm) 230
Cable Length 4 (mm) 230
Cable Length 5 (mm) 230
Cable Length 6 (mm) 230
Cable Length 7 (mm) 250
Cable Length 8 (mm) 260
Cable Length 9 (mm) 290
Cable Length 10 (mm) 300
Cable Length 11 (mm) 340
Cable Length 12 (mm) 380
Coil Lead Length 1 100
Coil Lead Length 2 110
Old Sep 11, 2019 | 01:56 AM
Greg in France's Avatar
Duke
Have you got my list still? Even if the lengths might be a tad short, because I have no cruise, the ends 90 degree or straight are definitely correct.
jagstuart
Sep 13, 2018 09:53 AM
Elkulichi916
May 13, 2017 06:52 PM
kennyjd
Mar 19, 2016 03:06 AM
98jags
Mar 6, 2013 12:02 PM
lostpinky
Oct 7, 2010 08:02 PM
