Impossible to change gear from "P"
Old May 10, 2015 | 03:46 PM
allexxx's Avatar
Default Impossible to change gear from "P"
Hello, last year I parked in the garage my XJS 6.0 v!" from 1995. Now I can start engine normally, but impossible to change gear. Can anybody help?? Is it mechanical or electic block?
I tried to open console, but do not see anything.
Alex
Old May 10, 2015 | 07:07 PM
Flint Ironstag's Avatar
Is your driveway / garage on an incline?
Old May 10, 2015 | 07:10 PM
drbill's Avatar
Alex
Rock the car back and forth, like you are trying to roll it. Release the handbrake first.
Old May 10, 2015 | 07:54 PM
Bill C's Avatar
It's most likely the "Gear Shift Interlock". It prevents you from shifting into gear if you don't step on the Brake Pedal first. The Brake Light Switch is not making the connection when you step on the brake (prior to shifting out of Park). Try tapping the Brake Pedal or tapping it sideways a few times. If the switch is completely gone and you need to move the car, try this fix.
Old May 10, 2015 | 09:59 PM
Bc xj's Avatar
What he said
Old May 11, 2015 | 02:13 AM
allexxx's Avatar
No, it is 100% flat in the undergraund complex of garages.
Old Oct 11, 2015 | 04:49 AM
allexxx's Avatar
Default Thank you.
I finally had time to try and it works.
Thanks again.
bamforp
Aug 14, 2024 05:36 PM
tomsjag
Jun 10, 2023 10:02 AM
Dz1rfj
Jul 17, 2018 10:29 AM
hen555
Sep 7, 2015 11:13 PM
XFR_Gold
Sep 2, 2015 12:24 PM
