Injector Bank firing order?
Old Feb 12, 2013 | 11:56 PM
jake21's Avatar
Default Injector Bank firing order?
Skimmed through my repair book and searched the web, couldnt find it.
Can anyone tell me the firing order of the injectors on the XJS from TDC?
Old Feb 13, 2013 | 12:54 AM
I am not aware of sequential firing of the injectors on the HE 5.3.
Now the memory bit, so look out, I may be fuzzy here. Quote me at YOUR peril.
They are wired in 4 groups of 3, and fire twice for each revolution of the engine and that is all 12. Being as the engine is "port injection" as apposed to "direct injection", that "squirt/s" sits behind the inlet valve and is drawn in at the crack of that valve.
I have never come across a timing sequence for the fuel side, only the ignition.
Now, the 6ltr, real late units as in X300 that have Nippon Denso engine management "may" have sequential" injection firing. I know my X300 AJ16 also with Nippon EM does have sequential injection firing.
Old Feb 13, 2013 | 11:59 AM
JameyXJ6's Avatar
I've wondered for quite a while why they did this. Doesn't the fuel pool on top of the valve when the injector fires with the valve closed? Wouldn't gas mileage be better if it were only firing when valve was open? Seems you could run a larger injector with better economy if they were sequential?
Daim
Nov 28, 2016 09:28 AM
duecedriver
Dec 25, 2015 11:47 AM
RoyLittle0
Sep 17, 2015 01:05 PM
Dickie_L_J_O
Sep 13, 2015 07:44 AM
jaguarbill
Sep 5, 2015 11:43 AM
