Inlet manifolds (appearance)
Old Jun 8, 2018 | 10:44 PM
Alan Lindsay's Avatar
Default Inlet manifolds (appearance)
Hi all,
Some may recognise my posts. I'm slowly doing up a 78 Daimler Double Six
As previously mentioned the engine bay was in appalling condition. Progress is glacial but steady, I'm still not sure what I have let myself in for.
I have been working on the inlet manifolds which I guess are the most visible and striking feature of the engine. They now look like new. I was wondering if anyone has tried applying a light coating of clear engine enamel onto the bright aluminium castings to retain their appearance and prevent oxidisation?
al
Old Jun 9, 2018 | 02:39 PM
ronbros's Avatar
turns yellow after time from heat!
Old Jun 10, 2018 | 12:45 PM
BradsCat's Avatar
but prevents the oxidation or rust issues. go with a high quality, hi-temp product and your yellowing issues may be minimized.
Personally I prefer a slight yellowing over the oxidation on the aluminum pieces and the rust on the steel parts.
Old Jun 10, 2018 | 03:19 PM
Jagsandmgs's Avatar
In the US we would use Aluminum Brightener designed
for pontoon boats. You don’t coat the aluminum, you just clean it occasionally.
Bio-Kleen M00109 Aluma-Kleen - 1 Gallon https://www.amazon.com/dp/B007H2RFOS/ref=cm_sw_r_cp_api_i_5EyhBbZV31EAR
Old Jun 15, 2018 | 06:18 PM
VancouverXJ6's Avatar
I'm getting my intake/exhaust manifolds and a few other things redone in chrome-like thermal coating. Reduced heat, increased HP and a sharp look. Good up to 1400F and much more resistant to damage then bare metal.
Spend the $200 and find a shop that does thermal coatings like that.
Old Jun 17, 2018 | 04:32 PM
ronbros's Avatar
exhaust manifolds ,1st ported & smoothed internally,then Ceramic thermal coated.
then inlet manifolds EXTRUDE HONED, very smooth and takes out the internal humps and bumps, injector protrusions, also opened up 1/8th inch alway thru, including the plenums!
outside painted RED, fins smoothed off for visual effect!
24yrs later , still looking good, better resolution also!
Attached Thumbnails Inlet manifolds (appearance)-vlcsnap-2018-02-11-17h42m05s513.png   Inlet manifolds (appearance)-jag-strut-brace-mom-ridin-shot-gun-v12-exhuast-mani-002.jpg   Inlet manifolds (appearance)-jag-strut-brace-mom-ridin-shot-gun-v12-exhuast-mani-008.jpg
Old Jun 17, 2018 | 04:47 PM
ronbros's Avatar
that coating does not hold up to exhaust manifolds and turbo housings ,it actually starts to melt off when it GLOWS RED>ORANGE!
N/A engines it works fine cooler temps, but at tubing bends it changes visual, been there done that!
still looks better than raw iron tho.
cdnjag
Interior
Nov 25, 2022 08:47 PM
Brake buster
Apr 11, 2015 11:39 AM
Rhett
Aug 14, 2014 10:47 AM
vincent661983
Jun 21, 2012 01:29 PM
kblood
Mar 8, 2010 06:23 AM
