Inserting Left Catalytic Converter with the engine installed
Old Nov 14, 2020 | 04:06 PM
mikebaker3's Avatar
Default Inserting Left Catalytic Converter with the engine installed
I screwed up. I changed the engine in my 90 V-12. Not my first time doing an engine swap on a v-12 XJS. Usually I take some safety wire and secure the front cats so that they are in approximate location. This Time I did not. I have been trying to fit the left front cat, but can't get between the steering rack and the frame. I took the heat shield for the rack boot out, but do not see clearance.
What am I missing?
Old Nov 14, 2020 | 05:04 PM
BradsCat's Avatar
why not take them off and not worry about it.
Old Nov 14, 2020 | 08:36 PM
mikebaker3's Avatar
And connect the exhaust manifolds to what?
Old Nov 14, 2020 | 08:55 PM
jal1234's Avatar
Originally Posted by mikebaker3
I screwed up. I changed the engine in my 90 V-12. (Snip)
What am I missing?
The rack needs to be moved down out of the way, and for more room, the subframe mount may need to come out. Or drop the rear of the subframe down. It's tight even with straight downpipes. More so with cat downpipes.
Old Nov 14, 2020 | 09:21 PM
Pirk's Avatar
What am I missing?
Are you talking these evil things? To get these out, if you've got the damn 2nd cats you've gotta drop those and the intermediates, otherwise just the intermediates. To get them back in, I get the downpipes on the manifold with two helicoils that aren't the heat shield ones. Then I get the heat shield in place and do the other two helicoils. Then I just rotate around tightening things - you can screw this up if you don't do an even tightening. You'll end up with the down pipe not sitting properly. I just screwed this up, so it's fresh on my mind The front pipe is about 1/4" lower than the rear pipe - check pic...
Old Nov 15, 2020 | 01:36 AM
Greg in France's Avatar
To these sort of non-cat downpipes
Old Nov 15, 2020 | 05:31 AM
BradsCat's Avatar
What Greg said. i just pulled a set off a parts car like this. No Cat's what so ever. We did have to take the downpipes off to get the motor out. Just no room to clear the front sub-frame and steering rack otherwise.
On my own car I know I removed both sets of original Cat's. I didn't wait for them to go bad from age.(A friend with an XJ6 had his Cat's go bad. We couldn't figure ut wy the car wouldn't start. Turns out it couldn't breathe at all from the Cat's crumbling on the inside) I replaced them with only one Cat on each side. I also removed the rear resonators. It's not dramatic but there is a noticeable difference in power. I personally like the low grumble sound the car now makes as well. It's a V-12 after all. It should let people know there is something special in there. .
Old Nov 15, 2020 | 06:35 AM
JayJagJay's Avatar
If the resources are available I would lose the CATS all together and even break out the combing at the top of the replacement downpipes if they have that when you get them. Makes for a lot more room.
I think if the heat shields, oil filter and shaft for the steering are moved and removed (all from memory) the cat on the LH side can be moved up, fitted and refitted. The RH, again from memory, by comparison has lots of room.
Old Nov 16, 2020 | 04:01 PM
BradsCat's Avatar
Steering shaft was the issue. Disconnect that and drop the steering rack and it might come out easily.
Old Nov 20, 2020 | 06:56 AM
mikebaker3's Avatar
Dropping the steering rack gave me enough clearance. Of course the next fun job will be getting the steering rack shims back in place as I reinstall the steering rack. Thanks everyone for the advise. It was spot on.
bknorwood
Oct 1, 2020 10:13 PM
Greg in France
Mar 22, 2017 02:27 PM
Safari
Apr 19, 2015 10:25 PM
BlackJack
Jan 7, 2010 07:02 PM
