inside the wiper motor
Old Feb 10, 2013 | 05:31 PM
J_C_R's Avatar
Default inside the wiper motor
Well, the semi-rebuild of the cat goes well. I've got the engine more-or-less doing what it's supposed to do, although I do need to get the full-throttle and kickdown switches wired up. Until then I'll take it easy...
The wipers don't work, and then did before I started working on the car, but I'm getting the voltages the Kirby book says I should be getting at the pins in the wiper "compartment". So I pulled the motor apart. Needless to say it's a mess, but it looks like a PO had a problem with one of the magnets, as it's been JB Welded back into position.
One thing I noticed is that of the three brushes, two of them (on the yellow and pink wires) move easily, but the one of the blue wire feels a bit tight. What is the recommended lubricant in this case?
On the motor magnets, you can see that one has a groove at the bottom, the next one at the top and bottom, and the next one at the top. Why would this be?
Thanks,
John
1987 XJ-S V12, 62000 miles
johndahlheimer
Sep 17, 2020 03:10 PM
HypnoGuru
Oct 23, 2018 09:53 AM
CaneCounsel007
Nov 13, 2015 09:05 PM
Saturbo
Sep 8, 2015 07:35 PM
XJsc-guy
Sep 2, 2015 11:43 AM
