Instrument cluster multiplugs
Old Apr 19, 2017 | 01:19 PM
Greg in France's Avatar
Default Instrument cluster multiplugs
Guys
I am working with a mate on his car (1983 V12 HE Coupe LHD), and we are R&Ring the instrument lighting, and trying to get the warning lights to work. Nearly there, but two problems that are driving us nuts:
We are stuck on getting (i) the High Beam warning light and (ii) the Rear Fog light warning light to work.
Somewhere I used to have a diagram showing which track on each of the two multiplugs that go into the back of the instrument cluster, did what. Needless to say I cannot find it!
Can anyone help PLEASE!!
Greg
Old Apr 22, 2017 | 03:15 AM
As nobody seemed to have such a diagram, I have made one, attached herewith. I am reasonably sure it is accurate, but it is just possible the oil pressure gauge and oil pressure warning light terminals might be confused. This is taken from a 1983 LHD USA V12 coupe. I cannot be sure it is accurate for other markets. Maybe worth putting into the stickies?
Greg
Old Apr 5, 2019 | 04:19 AM
Bez74's Avatar
Hello Greg
Thank you for the diagram attached - another previous owner issue where tacho wires were removed.
Will be able to re-wire again and then tick another one off the list
Steve
