Is The Italian Tune-Up A Myth? Does It Actually Do Any Good?
Old Aug 12, 2018 | 11:46 PM
Rivguy's Avatar
Not only "blowing out the carbon' but getting the motor and other systems up to proper operating temperature. keeping it hot enough to burn off carbon deposits on the plugs, piston, and gunk on the valve stems. Runs enough fuel through the system to allow the cleaning compounds to work as designed. Also gets the oil hot enough for moisture to evaporate properly. Even heating up the brakes through use will help keep moisture out of the brake system, especially drum brakes.That is why smaller engines that have to work harder to provide adequate performance often last longer than large motors in cars operated on short trips in town. Think little old lady driving to church once a week. That's why lots of cars with high mileage from commuting still run well. The best thing you can do for your car is drive it.
Old Aug 12, 2018 | 11:51 PM
Jagboi64's Avatar
Originally Posted by VancouverXJ6
I see your in Calgary, best case scenario floor it up and down the deerfoot during the rushour death-race. Lots of opportunity to floor it then slam on the brakes. There are a few range roads where they (cps) don't normally patrol to.
Or a drive up Sarcee or Shaganappi Trail does the trick too. No shortage of hills in Calgary.
Old Aug 13, 2018 | 12:57 AM
Keesh's Avatar
I can't explain how or why but the harder you push the Jaguar V12 the better it gets, and the better your fuel economy to.
Not only the V12, but also the 6 in line.
VancouverXJ6's Avatar
Yes but have to watch out for those ****ing camera trucks. Those *******s. Almost worth the money for the speed-trap reflective licence plate screen.
Old Aug 13, 2018 | 02:12 AM
Keesh's Avatar
I drive sometimes in Germany, a lot of highways no speed limits.
Old Aug 13, 2018 | 02:16 AM
Some Day, Some Day's Avatar
It's not ground speed that matters, it's more about putting load on the engine. So for example, if you are merging onto the motorway, use full throttle. Or find steep hills and accelerate up them. Keep "drive it like you stole it" in the back of your mind! Doesn't mean be a hooligan and be hard on the car, just give it some work to do instead of drifting along at small throttle openings.
Thanks. Yes, I suspected similar, and try to cane it up the odd hill, but there aren't many that are both straight enough and traffic-free enough to make it safe. I can find some if I go further out into the rural areas, however.
The other question is, how long does it need to be kept at high revs? Even on the more rural hills, I can seldom manage more than a dozen or so seconds at full boost before I start to run out of road. I've seen some people say it needs to be sustained for at least a few minutes, while others say a quick burst is fine.
Old Aug 13, 2018 | 03:36 AM
Agreed.
Get into it Alex, but watch out in the UK. If you wind it up too far for too long, you might run out of country and end up in the drink, HA.
All mine were driven hard, NOT stupid, but hard.
Long distances are the best, as in hour after hour at 3000rpm or more, really cleans the innards.
100% agree also, with the importance to get it UP to temp before any "clean out" is attempted.
Old Aug 13, 2018 | 04:06 AM
  #28
3,000 rpm? That's lower than I was expecting. I think I could manage that even here.
Road trip, here I come... when it's cooler.
Old Aug 13, 2018 | 04:32 AM
It is reality as I get older, oops, and the Gendarmes get smarter. So I sit at that rpm, and when needed, its gets the red line blast, usually passing a road train or 2.
After a while in the city/burbs, it takes a 100km or so to "feel" settled, so then it just gets better.
Same goes for the current S Type V6's.
Old Aug 13, 2018 | 04:36 AM
  #30
orangeblossom's Avatar
Originally Posted by Grant Francis
Agreed.
Hi Grant
Still 'Buzzing' about finding those elusive Fuel Pipe Clips!
But when I'm on those Country Roads, I've somehow taken to using 2nd gear, where the rpm is at around 3000 and overall after that She seems to run much better, although of course She drinks a lot more 5 Star
Where I can almost hear her say, 'don't mind if I do but you better make mine a double'
The only downside being, that I'm getting paranoid about one of those Fan Blades flying off
Do you happen to know if there was ever an option to fit an XJS with a steel fan?
Old Aug 13, 2018 | 06:29 AM
  #31
Greg in France's Avatar
Maybe the early pre HEs? But OEM cream-coloured fans, as per the HE OEM ones from a construction and solidity angle, are available still, but in a slightly larger diameter as used in some saloons and the Daimler limo. Black Country Jaguar have them. I fitted one to a mate's car, which entails removing and discarding the shroud. It needed a 20mm spacer and longer studs being made, but cools the engine incredibly effectively. The normal clutch unit fits fine. Of course, a resourceful guy like you OB could cut down the blades and keep the shroud!
Old Aug 13, 2018 | 06:41 AM
  #32
Doug's Avatar
Originally Posted by Some Day, Some Day
The limit on the expressways is 100 kph, and while there are a few areas of road where I can drop the car into second and briefly scream up to 5,000+ rpm, I can't sustain it without getting wildly over the speed limit.
Use first gear rather than second !
Old Aug 13, 2018 | 06:47 AM
  #33
Doug's Avatar
Jaguar used steel fans until 1981-82 or so. On the XJS I think the change to plastic was shortly before the introduction of the HE engine.
Anyhow there's no guarantee against breakage with the steel fans. Check this out:
Welcome to Jag-lovers - Members Photo Viewing Page
Old Aug 13, 2018 | 06:49 AM
  #34
Doug's Avatar
Agreed.
Right !
They're not made out of glass
Old Aug 13, 2018 | 07:14 AM
  #35
Daim's Avatar
Originally Posted by Doug
Right !
Ans they can also get wet, as they aren't made of sugar...
Old Aug 13, 2018 | 07:50 AM
  #36
Oh dear!
Maybe plastic would leave a smaller dent?
Old Aug 13, 2018 | 08:03 AM
  #37
Like this you mean?
Facelift Fan cut down to fit inside Pre-Facelift Fan Shroud
Fan with Spacer fitted
Old Aug 13, 2018 | 09:37 AM
  #38
JagCad's Avatar
Cruising along in OD is not effective in "blowing" out the carbon. figured that out in my long departed 88 Ford Tbird.
Even my Jeep gets a "work out" from time to time by using D2!! Same for the LT1 powered Jaguar.
Gotta get the r's up. 3K minimum....
Carl
Old Aug 13, 2018 | 10:22 AM
  #39
Like this you mean?
Terrific OB. Just like that. Much nicer than that horrible flimsy black effort now being sold.
Old Aug 13, 2018 | 11:59 AM
  #40
sidescrollin's Avatar
Another big reason commuter cars with high mileage run well is that the mileage is relative. Starting your car creates as much wear as 1,000 highway miles, because there is no oil at startup. On the highway the engine has a constant film of oil to protect it, which is why a 3 year old car with 200,000 miles is not at all the same as a 15 year old car with 200,000 miles.
