It's ALIVE again!
Old Mar 16, 2012 | 07:07 AM
Mish_Mish's Avatar
Originally Posted by JameyXJ6
I started thinking about the mods I've made and decided to make a list.
So far I've:
*Swapped engine from the original 83 to an 85. The 83 had blown head gaskets and unknown damage from heat, so I picked up a low mileage V12 from an 85 and just switched the intakes and externals.
*Removed A/C compressor, lines and cooler. I live in northern New England and it's a convertible. I'll only have it out on days when I can put the top down, so the A/C is kinda pointless.
*Removed air pump, idler pulley, airtubes, tapped and plugged air injection holes in intakes with allen screws.
*Removed cruise control bellows. (I prefer my foot on the pedal!)
*Removed Lucas alternator and replaced with higher AMP GM alt.
*Gutted the insides of the downpipes and hollowed out cat-converters.
*Removed factory mechanical fan and replaced with electric.
*Replaced fuel injection harness and most all of under-bonnet wiring.
*Upgraded ECU
*Replaced 15" wire wheels with Jaguar 16" mag rims and 235/60/16 tires.
I'd guess I've probably easily removed over 200 lbs of "stuff" with the above mentioned mods.
Next on the list is to remove factory fuel regulators and replace with single adjustable regulator with built in gauge.
Replace factory airboxes with cold air intake and low restriction air filters.
I've got a few other things on my list I plan to do as well.
This list almost identical to mine, except I still have original alternator, but my starter is gear reducing Nippondenso (awesome improvement).
Do you mind telling me that Upgraded ECU exactly means?
Old Mar 16, 2012 | 07:14 AM
JameyXJ6's Avatar
Let's find out!
I think that the injectors fire in 4 groups of three, so are the BMW versions wired the same?. If so, that would be 2 wires for each group = 8 in total?
If this is correct, then you just carefully ensure the new harness wires go into the same places as the old ones did on the power resistor?
Greg
Yes, the injectors fire in 4 groups of 3, but I am unfamiliar with the BMW harnesses and how they are configured. For that you'd have to have someone elses imput!
Old Mar 16, 2012 | 07:17 AM
JameyXJ6's Avatar
I went from a 6cu to a 16cu. It was on the later models.
Old Mar 16, 2012 | 07:26 AM
Mish_Mish's Avatar
I heard that 16 CU does not work on HE that easily, did it plug and play into '83?
Old Mar 16, 2012 | 09:24 AM
Greg in France's Avatar
The 16cu is an exact swap for the 6 cu. It has more reliable circuitry and I think more modern, than the 6 cu. This info comes from AJ6 Engineering, the foremost authority on these matters, AFAIK.
Greg
Old Mar 16, 2012 | 10:21 AM
Mish_Mish's Avatar
Greg
Ok, I just bought one: JAGUAR XJS V12 LUCAS ECU ECM FUEL DAC4118 16cu 84526B | eBay
Hope it works, or you'll owe me a coffee and croissant
Old Mar 16, 2012 | 11:58 AM
It will be a pleasure! If I am not passing by your way shortly; I will fax you $20!
Greg
Old Mar 16, 2012 | 12:32 PM
  #28
Mish_Mish's Avatar
I might be, if my wife finally makes me go see your neighborhood. So far I was effectively finding reasons to stay in my village
Old Mar 16, 2012 | 04:44 PM
warrjon's Avatar
My 89 has a 16CU from the factory.
Old Mar 16, 2012 | 06:17 PM
  #30
Mish_Mish's Avatar
Yes, but my '82 was made by warier ninjas in the mountains of Japan!
Old Mar 16, 2012 | 07:58 PM
  #31
JameyXJ6's Avatar
Mine was made by British Ninjas.
Old Mar 19, 2012 | 04:51 PM
  #32
JameyXJ6's Avatar
Just adding this photo to the thread as this was the first time in months the Jag had seen sunlight!
Old Mar 19, 2012 | 06:51 PM
  #33
Mish_Mish's Avatar
Greg
Got it in the mail today, car runs! It does not hold idle as good and it seems a bit rich on the mixture, so I assume some tuning is in order.
Overall, it is a success, thanks!
Old Mar 19, 2012 | 08:52 PM
  #34
M90power's Avatar
how do you tune your setup?
Old Mar 20, 2012 | 07:19 AM
  #35
Mish_Mish's Avatar
Kirby Palm describes procedure in detail, but it has to do with adjusting one and only potentiometer on the ECU box. The rest is adjusting TPS position and measuring O2 sensor readings. to make sure car runs not too rich, or lean.
Old Mar 20, 2012 | 10:48 AM
  #36
JameyXJ6's Avatar
Just for the record, you can make a cheap and easy adjustment tool for the ECU lean/rich adjuster. I took a 6 inch long piece of metal fuel line (I forget what size though) and ground the end of it a little thinner, then squeezed a flat spot onto it. It works quite well.
Old Mar 20, 2012 | 10:50 AM
  #37
JameyXJ6's Avatar
Drove the car for the first time today from my driveway to my neighbors and back. Each driveway is nearly a 1/4 mile long, but the car isn't registered so I didn't dare take it out on the road. I put the top down and the ole' girl seemed to go pretty good!
Here's a pic with the top down but without the parade cover over the top.
Old Mar 20, 2012 | 04:10 PM
  #38
M90power's Avatar
shes lookin good. man, i cant wait to take mine for a drive.
Old Mar 20, 2012 | 07:38 PM
  #39
JameyXJ6's Avatar
I'm thinking of picking up some 20-day plates tomorrow morning...it's supposed to be in the 80's here!
Old May 17, 2012 | 11:18 PM
  #40
M90power's Avatar
funny, i thought the injector harness was the hardest part.
everything else was pie. still took for Effing EVER.
