jaguar facelift xjs v12
Old Feb 9, 2019 | 09:10 AM
nick michael's Avatar
Default jaguar facelift xjs v12
the car has been sitting for two months ,today when i started first time the heater fans are not working at any setting cannot hear any noice car heating up well any reasson for this please help
Old Feb 9, 2019 | 01:44 PM
Noah's Avatar
So nothing happens when you turn the dial for the fans? Are any other electrics not working, such as windows, radio, electric seats, turn signals? I had intermittent issues when several electrics would go out at the same time. It turned out to be a relay that was failing. It was one of the relays in the area under the glove box.
Old Feb 9, 2019 | 02:43 PM
Many thanks have you any idea which relay
Old Feb 9, 2019 | 05:03 PM
Noah's Avatar
I found my earlier thread on the issue and pasted the link below.
It's the auxiliary ignition load relay. It's next to the seat heater relay. As I remember it, they are on the passenger side (LHD) under the glove box. I removed the lower fascia to expose the relays. This may not be your problem, but it's an easy item to check. If you read through the thread, you can see exactly which electrical items were and were not working before I replaced the relay. If it's only the HVAC fans not working then prehaps it's a single fuse.
https://www.jaguarforums.com/forum/x...e-start-161211
Old Feb 9, 2019 | 08:55 PM
mghirsch's Avatar
If you have power to the fans, you may have the problem I had. Bad/worn brushes. I pulled the motors and replaced the brushes. I was able to get them at the local hardware store, but I had to file them down to fit.
chXFS
May 30, 2022 11:02 PM
CruizinKev
Oct 9, 2017 09:12 AM
hoodun
Oct 30, 2012 08:23 PM
priest2705
Mar 4, 2011 09:47 AM
