Last time I ask for help on this issue... trans shifts?
Are you still running two fuel regulators?
I know you just replaced the B-bank unit (I think) but do you still have the inlet (A-bank) regulator in place?
If so, bypass it and see if anything changes
Long story short I had a terrible bucking/cutting out problem with my '88 XJS and it was the inlet regulator that had failed
Bypassing the inlet regulator.....
Note item #10 and #1 in this illustration:
https://parts.jaguarlandroverclassic.../brand/jaguar/
Eliminate item #1 by simply disconnecting it from the fuel inlet pipe and the inlet regulator
Run a new hose from the inlet pipe directly to item #10. The #10 pipe has a knob at the end that you can slip your new over and secure with a clamp
3/8" ID hose as I recall
Looks like you have been chasing this for a little while - was going back through the forums chasing other stuff and found some of your previous posts
July 2017 looks like you had water in your fuel system - left overs from when you did your fuel tank?
August 2017 very dirty fuel from your sump tank.
January 2018 - having similar issues to what you are having now - so the title of this thread makes more sense to me now, also when you changed from 2 coils to 1
Interesting to read the XJS rev limiter thread #33 https://www.jaguarforums.com/forum/x...-153911/page2/ saying he found and fixed his issue
I am understanding your frustration just that little bit more
Steve
Steve
Steve
Steve
Alright I’m in a positive place now. I did remove the inlet fpr that didn’t do anything... then I was sitting with it running and just looking around. I started revving it with the cap stand and opened it wide and it started idling funny, up and down. that was new... so I for whatever reason pushed the fuel enrichment switch and the car almost quit. Then it went back to idling weird. So I clicked it again and held it. It revved up and down faster. So I got in the car and revved it trying not to hit the enrichment switch and seemed like it slowly revved past 5k... then I mashed the throttle and instantly cut to the rev limiter feeling back at 5k. I’m thinking the fuel enrichment switch is junk!
I found an old thread on enrichment and it made me less positive. Was saying to test the throttle enrichment switch... at idle if you push the switch and it changes idle significantly that the switch is good. I guess it’s back to fuel pressure testing next
