Light in Ignition key?
Old Jul 28, 2013 | 09:09 AM
Chuck D's Avatar
Default Light in Ignition key?
The key for my '93 XJS has a push button on it and a small light inside to illuminate target when inserting key. Apparently the battery is dead. How do I get the key open to install new battery? Thanks.
ChuckD
Old Jul 28, 2013 | 10:26 AM
motorcarman's Avatar
With an EXTREMELY sharp razor knife.
You can split it along the seam and replace the 'button-cell' battery.
I just press the halves back together, reinsert the lighted part and let the rest of the key hold it together.
The other alternative is to buy the lighted part from Jaguar as an assy and hope that it is not NLA. (I'll bet it is No Longer Available from parts dept.)
I have several keys for my 1992 XJ40 and every few years I buy a battery and replace it in one of the keys.
The battery # is 625A
bob gauff
Old Jul 28, 2013 | 10:30 AM
AllanG's Avatar
To get the key open, press the rectangle with JAGUAR written in it on the back of the key and pull the two halves apart.
The battery/light is one piece so you can't replace it easily without doing a bit of surgery
The part number for the replacement is BCC9959 but I doubt you will find it easily.
It's fully described in the owners handbook if you have it.
Cheers,
Allan
Old Jul 29, 2013 | 12:06 PM
Chuck D's Avatar
Smile Problem solved
Thanks to your help I solved the problem.
Old Jun 24, 2014 | 09:07 PM
afterburner1's Avatar
Would appreciate the reassembly sequence. I open mine and the parts dropped out. Never got a chance to see them assembled. I reassembled it several times, but the button doesn't work or the light remains on.
dsnyder586
Dec 29, 2024 07:39 PM
99xk8guy
May 28, 2024 09:36 PM
JarodL
Mar 7, 2024 01:39 AM
XJsc-guy
Nov 23, 2015 01:56 PM
jagent
Sep 12, 2015 01:40 AM
