lost power to several accessories.
Old May 29, 2014 | 02:22 PM
M90power's Avatar
Default lost power to several accessories.
so my 85 XJS coupe is back to life but in my haste to get rid of most of the Lucas stuff in the car, i mustve jerked a power wire somewhere.
things that no longer work
power windows
electric door locks
headlights
tail lights
brake lights
license plate light
now i yanked the headlight relay so im pretty certain thats why the headlights dont work anymore. im curious as to what sort of amperage the headlights draw and whether i can get away with running a toggle switch set rated for the appropriate amp's to run the headlights on one switch, the tails on a seperate switch. the brake lights im more curious about. do the brake lights run off a relay or do they get power through the brake pedal switch? im thinking of just running power through the brake switch to run the brake lights.
power windows and electric locks are more pressing since its hot as crap outside and thieves are a thing. i get the feeling they share a power source somewhere.
any help would be tremendously appreciated. ive got a chassis diagram around here somewhere but cant for the life of me find it.
Old May 30, 2014 | 05:11 AM
No sure of your market, but some fuses are involved there.
The brake lights on my '85 had no relay.
The amps for the headlights (and the others on that circuit) is easy. Total the wattage, divide by the voltage used (12v in this case) and the answer is the amps. Dont forget the small parkers, number plate lamps, and Hi beams.
Old May 30, 2014 | 01:29 PM
M90power's Avatar
alright. replaced a fuse and flipped a couple connectors and now the headlights work, the brake lights work, and the power windows work.
still no LP light, no tails, and no reverse light. nor did changing the electric lock switch work
but thats progress right?
99xk8guy
May 28, 2024 09:36 PM
pilot435
Apr 8, 2016 06:16 PM
Thang Nguyen
Oct 12, 2015 01:25 AM
GGabriel
Sep 18, 2015 08:44 PM
XFR_Gold
Sep 2, 2015 12:24 PM
