Manifold shield AJ16
Old Mar 13, 2014 | 10:57 AM
JohnnyM's Avatar
I have a new gasket and olive.
It's just dawned on my that maybe I have to undo both gasket/manifold connections in order to get the movement necessary to remove the front manifold.
If so I will need another olive.
Any thoughts?
Cheers J
Old Mar 15, 2014 | 03:57 AM
JohnnyM's Avatar
Could it be that the manifolds must be removed at the same time even if it's just the front that I'm swapping over.
This is frustrating as I have all the parts I need I just can't find the info. On the verge of taking it to a mechanic
Old Dec 21, 2014 | 08:41 AM
Vee's Avatar
Vee
I'm about to take on a similar project. Can you tell me how this worked out for you in the end?
I'm replacing my rear manifold. I have the o-ring and two studs ordered for the down pipe connection, as well as a new gasket for the manifold/engine block connection.
Old Dec 21, 2014 | 11:32 AM
RagJag's Avatar
JohnnyM, be very sure to torque the replacement manifold following instructions as to which bolts to tighten first. Do this in at least 3 stages so you don't put too much uneven pressure on the manifold. These things will break if not torqued properly.
luck, RagJag
Poet
Feb 7, 2025 02:18 PM
Joachim1167
Nov 7, 2020 09:18 PM
LilaJagHubby
Oct 6, 2015 02:56 AM
BSM
Sep 25, 2015 05:00 PM
