Marelli from Lucas swap.
Old Jul 31, 2016 | 07:26 AM
neil-s's Avatar
Default Marelli from Lucas swap.
Hello folks,
After my 1989 V12 XJS dropped a valve seat last month, I have a chance of a new engine, however its running the Lucas set up and not the marelli. I assume its only a matter of swapping the distributor and connecting the pully/flywheel pick ups and I guess the crank pully itself? Any advice would be a great help!
Thanks,
Neil.
Old Jul 31, 2016 | 02:02 PM
Neil,
I've moved your question from General Tech Help to XJS forum. Members here with the same model will be able to help.
Old Jul 31, 2016 | 02:31 PM
Doug's Avatar
Originally Posted by neil-s
Hello folks,
Thanks,
Neil.
Perhaps flywheel as well? Not sure.
Also not sure about the *mounting holes/brackets/whatever* for the flywheel and crank pulley sensors. For the front sensor, at least, I think a different t/chain cover was used?
Old Jul 31, 2016 | 02:32 PM
Daim's Avatar
The rear is a different part number. The front is a bracket fitted inplace of the timing mark thingey...
Old Jul 31, 2016 | 03:46 PM
baxtor's Avatar
A bracket could possibly be fabricated for the front pulley sensor but it was originally mounting by boss cast into timing cover. Rear mount is in lower flywheel cover so that would be easier to swap out than front.
Old Jul 31, 2016 | 06:55 PM
warrjon's Avatar
Hello folks,
Thanks,
Neil.
Is your original engine rope or Lip seal, if its lip seal I would be keeping the original block, and swap the just the bad head and piston if needed.
JigJag
Mar 21, 2021 08:08 PM
jal1234
Aug 1, 2016 08:43 AM
polarisnavyxj
Jul 26, 2016 08:17 PM
that guy
Jul 6, 2016 11:36 AM
