throttle potentiometer wire color confusion
Old Jul 6, 2016 | 08:32 AM
that guy's Avatar
Default throttle potentiometer wire color confusion
Hello,
I am replacing my damaged red Lucas throttle potentiometer with a new red Lucas pot, however, the wire colors do not match, and the connectors are different. The jaguar electrical schematic has the wires labeled as yellow with pink stripe, yellow with black stripe and yellow with brown? stripe. The new potentiometer has a red, green and yellow wire.
This is on a 1992 v12
this is the connector in the car:
this is the old Lucas:
this is the new Lucas:
Old Jul 6, 2016 | 10:54 AM
Greg in France's Avatar
Any connector will do. The Tpot wires and their loom equivalents are:
Red: goes to Yellow/Pink 5 volts
Green: goes to Yellow/White Signal out
Black: goes to Yellow/Black 0 volts
If you connect them up, you should find the variable signal on the Green wire - which should be connected to the Yellow/white in the loom. The yellow/pink supplies the basic 5 volt input.
To set it:
Switch on ignition, without starting engine, andusing a voltmeter check that the signal output on the green wire is 0.32 volts(+ or - 0.02 volts) with the capstan wheel in the closed throttle position.Adjust as necessary via the 2 clamping screws.
Greg
Old Jul 6, 2016 | 11:36 AM
that guy's Avatar
Thanks Greg,
That is the information I was looking for.
I am assuming that the Yellow wire on the new Tpot will connect to the Yellow/Black wire and the Red and Green wires will connect as you have described.
Paul
NTL1991
XJ40 ( XJ81 )
Apr 19, 2016 05:40 PM
Jaguar Forums Editor
XE ( X760 )
Apr 18, 2016 02:57 PM
retriever-007
Apr 8, 2016 03:16 PM
Dremorg
Apr 8, 2016 08:32 AM
Jaguar Press release
Apr 7, 2016 08:58 AM
