Master Cylinder Fluid Adapter/Grommets
Old Aug 14, 2016 | 06:43 AM
JigJag's Avatar
Default Master Cylinder Fluid Adapter/Grommets
I've searched and come up empty handed I'm hoping someone has a tip for me. I'm needing to replace the fluid adapters and grommets on my 1986 master cylinder. I can't find these grommets for a pre-facelift XJS. I can't find the adapters at all.
Does anyone know part numbers for either? Even proper term for the adapters might help. Are the pre and post facelift master cyls the same part?
Also, if I wanted to remake the metal lines from the reservoir to the cyl what type of tubing should I use? I'd like to rd-route them along the firewall and fender.
Old Aug 14, 2016 | 07:00 AM
JigJag's Avatar
RTC1129. Apparently all I had to do was ask here. Promptly located them after posting. Now to find them in the us if possible.
Old Aug 14, 2016 | 08:09 AM
ptjs1's Avatar
Jigjag,
If you're talking about the master cylinder service kit which includes the fluid adapter nozzles, then the part number is AAU6839. You can see all the part numbers and diagrams on the Jaguar parts website.
The price in the UK is £24. Just order it for collection from a Jaguar Dealer in the US and there are no shipping charges.
Good luck
Paul
PS facelift XJS uses an ABS system which is completely different from your pre-ABS setup.
bigdhenderson
Dec 12, 2016 10:52 AM
EZDriver
Apr 12, 2016 06:30 PM
Travis O'Gallagher
Apr 3, 2016 02:49 PM
JagSTR2004
Mar 31, 2016 08:22 AM
Jan 22, 2006 12:18 AM
