Mystery Non Factory Fuel ? Device
Old Oct 14, 2016 | 10:43 PM
PaulRoper's Avatar
Default Mystery Non Factory Fuel ? Device
Has anyone ever seen or know what this thing is or is supposed to do?
It was connected on the Right hand side of Engine- between fuel rail and the RHS regulator.
It 240mm x 32mm, brass- weighty.. and rattles..
Attached Thumbnails Mystery Non Factory Fuel ? Device-dscf8006.jpg   Mystery Non Factory Fuel ? Device-img_0674.jpg   Mystery Non Factory Fuel ? Device-dscf8030.jpg
Old Oct 14, 2016 | 10:52 PM
Cambo's Avatar
It's probably full of lead pellets, someone's attempt at a lead substitute when fuel switched to unleaded...
Old Oct 14, 2016 | 11:23 PM
PaulRoper's Avatar
Well.. that would explain weight and the rattle!
Old Oct 15, 2016 | 12:27 AM
PaulRoper's Avatar
Thanks Cambo,
turns out you are correct. Got it apart. - Lead Pellets in steel cages and a pair of magnets on the exit !
Old Oct 15, 2016 | 12:41 AM
Jagboi64's Avatar
Somebody had zero knowledge of chemistry, since lead in fuel wasn't metallic lead. The V12 doesn't need lead anyway, it already has hardened valve seats.
Old Oct 15, 2016 | 06:51 AM
paydase's Avatar
Yes, zero chance to produce significant amounts of lead tetra-ethyl, which is the useful stuff, by just flowing gas through a lead pebbles bed.
There are other devices that are sometimes mounted on the fuel circuit of classic cars, e.g. Eurocat containing tin based pebbles, which are claimed to act as oxygenation catalysts for fuel burn and/or to load some tin compounds in the fuel with the aim to better protect valves seats against wear when not using leaded fuel... Not very conclusive either
dsd
May 3, 2017 04:59 PM
hakunti
Oct 22, 2016 08:09 AM
MiniFarm
Oct 21, 2016 02:50 AM
Eaa
Oct 14, 2016 11:57 PM
rf69
Oct 14, 2016 03:47 PM
