Mystery Vacuum valve
Old Mar 29, 2016 | 07:19 AM
scottpeterd's Avatar
Default Mystery Vacuum valve
As I'm doing spring cleaning on my new toy (1992 Facelift Convertible), I found two devices that I can't identify.
They are both on the A bank. The first one is firmly mounted on the side of the intake manifold near the front of the engine. The second on is dangling under the pressure accumulator on the brake. I found this when bleeding the brakes.
They are Nippon Denso. #'s written on them are 184600-1120 and EBC 3731.
Any idea what these are?
Old Mar 29, 2016 | 07:26 AM
Doug's Avatar
The blue widget is a 'solenoid vacuum valve'
Part no. EBC3731 | Solenoid vacuum valve parts from Jaguar Heritage Parts UK
Old Mar 29, 2016 | 07:32 AM
Doug,
Any idea what it is used for? And why would there be two of them on the A bank, rather than one on the A and one on the B?
Old Mar 29, 2016 | 08:59 AM
JayCee's Avatar
On my 94, one is near the front of the A bank intake and is for the fuel pressure regulator / hot start system.
The other is under the intake at rear of the A bank and is for the air switching valve, which controls the air pump distribution (emissions).
Sorry... for some reason I am unable to download the pics.
You can download the workshop doc at https://www.jagdocs.com inexpensive and very valuable. It has detailed diagrams of all the vac lines.
Old Mar 29, 2016 | 09:18 AM
Safari's Avatar
If I am correct, that valve on a '92 is used to provide vacuum to the cruise control bellows.
Mark
Old Mar 29, 2016 | 02:11 PM
Eaa's Avatar
Eaa
Mark
on a 91 also, as I recall, at least it looks very similar, found on the forward right side of the engine
Old Mar 30, 2016 | 04:52 AM
NathanDD6's Avatar
Blue thingy is part of a redundant cruise control device, as a back-up if the primary system fails if I remember correctly, I could be wrong though.
Old Apr 3, 2016 | 06:36 AM
I think JayCee is correct.
I started to get into this because I found the valve dangling by the vacuum lines under the intake manifold.
Of course as soon as I moved it to inspect it, the vacuum lines crumbled, and it wasn't possible to figure out how they were hooked up.
Doug: that pic is invaluable. I've not been able to properly replace the lines.
Thanks to all for the help
Old Apr 3, 2016 | 07:46 AM
JTsmks's Avatar
Nathan is correct about the cruise control add on. Mine was on the front of the manifold (I removed it, cruise works fine). Not sure about the one under the accumulator . http://www.kwecars.com/technical/v12...ows-explained/
Old Apr 3, 2016 | 08:33 AM
Ok, so forward one is part of cruise control. Aft one is part of the air injection system.
Old Apr 3, 2016 | 08:48 AM
JTsmks's Avatar
That would explain why I didn't have the rear one as my air injection system has been removed.
Old Apr 3, 2016 | 09:07 AM
JagCad's Avatar
Good place to connect a vacuum guage for diagnostic purposes.
Make sure it is securely plugged, o'wise it is an uneeded vacuum leak..
Carl
xjtom
Mar 31, 2016 04:16 PM
nick.R
Mar 26, 2016 06:52 AM
MonacoDK
Mar 25, 2016 06:30 PM
garyofnyc
Mar 25, 2016 05:17 PM
