NEED HELP
Old Apr 14, 2018 | 03:13 PM
Sylvain's Avatar
Default NEED HELP
Hi,
My car is at the repair shop since last fall
We have problems finding parts
We desperately need for this
It's an XJS 6.0 v-12 1995 number 11946 and I need exhaust and inlet valves
Thanks for you help
Sylvain
sylvainpoirier@me.com
Old Apr 14, 2018 | 05:02 PM
avern1's Avatar
SNG BARRATT has exhaust valves listed as in stock. Not much luck on the inlet valve. You might try Terry's Jaguar they might be able to help out.
Old Apr 14, 2018 | 05:07 PM
warrjon's Avatar
Be careful buying 6.0L valves they are shorter than both 5.3 pre-HE and HE also check the retainer groove is in the correct place, I had to shorten all my inlet valves 0.020" and exhaust valves did not have radiused margin.
Part numbers do not necessarily correlate with correct part.
Old Apr 14, 2018 | 07:34 PM
Sylvain's Avatar
Thank you for your quick replies !!!!
devxiav
Mar 1, 2013 07:23 PM
vitus
Nov 15, 2012 03:21 PM
jefecito87
Jun 23, 2010 02:29 PM
soccerstar10
Sep 1, 2007 05:15 PM
