new belt squeak
Old Feb 7, 2018 | 01:50 PM
J_C_R's Avatar
Default new belt squeak
The car is in the garage for repair of a variety of minor ills, one of those being belt replacement on the alternator, power steering pump, and a/c.
Just got it back together, and I now have a squeak (or squeal) that I didn't have before.
I don't have the AC compressor in the V anymore. I chucked it a few years ago and hung a Sanden compressor where the air pump use to be. This system has worked well from initial installation until today. The Sanden was purchased new. All the replacement belts are new and were purchased yesterday.
Anyway, the squeal is coming from the compressor area. When the engine is running, and the compressor is not engaged, the squeal is fairly pronounced. However, when the compressor kicks in, the squeal virtually goes away.
Since I did nothing to the compressor (the belt tension is adjusted at an idler pully) my first thought is that it's a belt issue, but I can't see any slipping, so would a belt that is too tight cause this? Any thoughts on how to diagnose this further?
My car has an electric water pump and electric fans, and this noise persists regardless of if they are on or off, so I'm not mistaking the source of the noise.
Thanks,
John
1987 XJ-S V12
Old Feb 7, 2018 | 03:13 PM
Reyaj's Avatar
If it squeals when the a/c isn't on but stops when it is on the cause is the bearing in the a/c clutch excess belt tension could cause this and lead to eventual failure of the a/c clutch bearing. From my experience with sanden a/c compressors in Chrysler applications they seem pretty reliable and bulletproof for the most part.
Old Feb 7, 2018 | 04:56 PM
J_C_R's Avatar
Thanks for that Reyaj! A turn of the wrench and squeak is gone.
Old Feb 7, 2018 | 07:16 PM
macdoesit's Avatar
Banned
On cold start I have a squeal and after a couple minutes it goes away ??
Whirlinturbin
Jan 10, 2016 08:20 PM
Bacardi 151
Jun 1, 2012 03:16 PM
2000blackxkr
Sep 13, 2009 10:28 PM
McJaguar
Jan 28, 2009 11:08 AM
