"New" dash veneer cracked already!
Old Mar 19, 2013 | 02:02 PM
DenverDRS's Avatar
Default "New" dash veneer cracked already!
It turns out my fears on the new wood veneers I installed came true. There is a hairline crack in the finish on the glove compartment already! The set lasted 20 years in the UK! The arid Colorado climate took its toll in a week! I'm really disappointed. The car looked almost new on the interior.
If only I could find an interior wood set made from Aspen trees... "sigh"
Old Mar 22, 2013 | 06:43 PM
gkazimir's Avatar
That's disappoointing...perhaps the small crack gives it character? Wood is a challenge in US weather, that's for sure!
Old Apr 14, 2013 | 05:35 PM
Eskr's Avatar
Hello fellow Coloradan!
So I was looking at replacing my wood veneer as well. After reading your post and having owned another car that had much thicker wood veneers that STILL cracked (Chevy G20 van conversion), I am hesitant to try this. It's so dry here in Colorado that owning a humidifier for your well-insulated house is a must, if that tells you anything.
So I was thinking of maybe replacing the wood veneers with those polyurethane kits they sell. Yes, It's not wood, I get that, and I hate to consider it, but reality is, no wood lasts in Colorado. Thoughts on this?
Eskr
Old Apr 14, 2013 | 05:56 PM
Oddrods's Avatar
I redid all the wood in my Jag using 3M Di-Noc Vinyl wood grain followed by 3-4 coats of Duplicolor clear and so far it looks great.
Old Apr 14, 2013 | 11:01 PM
buddyluv's Avatar
Talking Better Overcoat
I used Valspar Exterior grade polyurethane clear. To duplicate the original thick layer of fiberglass clear I put on about ten coats sanding until the last coat. This paint is rated against heat(sun), cold and water(moisture). I got it at Home Depot, but valspar is sold everywhere. Best stuff to use. Hope this helped.
Old Apr 15, 2013 | 09:40 AM
sidescrollin's Avatar
can you put more sealer on it or something? I just don't understand how a sealed piece of wood cracks. The stuff that usually goes on is polyurethane and that doesn't really dry out, it just gets damaged and cracked from the sun.
Old Apr 15, 2013 | 10:05 AM
Roger95's Avatar
I'm currently refinishing the wood in my '96 VDP with a 3-part product called Awl Brite. It's nasty stuff to apply but so far so good. The veneer itself on the two front door cards is cracked through and must be replaced but the rest of the car's veneer looks good except for the finish being cracked and yellow.
Old Apr 15, 2013 | 09:31 PM
Flint Ironstag's Avatar
Check out SARC's Jag. True, it's not wood (may be important to you), but it looks damn good.
Poet
Oct 6, 2015 09:40 PM
flyrr100
Sep 29, 2015 03:47 PM
Fraser Mitchell
Sep 19, 2015 11:46 PM
dstary
Sep 19, 2015 09:47 AM
jaggermang
Sep 8, 2015 07:07 PM
