New exhaust
Old Apr 13, 2015 | 08:46 AM
malc4d's Avatar
Default New exhaust
Its getting to that time . . . Options for a complete system 1991(92 MY) early facelift Cat.
Jag parts or custom SS ?
Old Apr 13, 2015 | 08:54 AM
Doug's Avatar
My experience is that Jaguar used high grade stuff when building exhaust systems. I'm pretty sure SS was used in some cases. If you can find a true OEM system, I'd go that route.
Old Apr 13, 2015 | 08:57 AM
Lee Palmer's Avatar
Malc4d,
I got a replacement stainless steel exhaust recently and then had to do some maintenance to various underbody parts. Luckily the exhaust that I purchased was a pattern part and as such had the correct joints to allow disassembly. Some custom exhausts are fully welded in place as as such can never really come off without being destroyed. Therefore please be careful in this regard.
Lee.
Old Apr 14, 2015 | 09:27 PM
malc4d's Avatar
ITS DAMM hard trying to get a complete system. ...
Old Apr 14, 2015 | 11:36 PM
Sarc's Avatar
Agreed. I went through the same pain a year or so ago. At one point I had a full Kiesler 3" stainless system on the car but I hated it because it was too noisy. It also went underneath the diff, as oppose to the standard fitment of going above it. This significantly reduced my ground clearance and the exhaust bottomed out regularly.
Eventually, as we had to replace the cats to pass smog I had my man take it to a shop and make the cats and pipes from the downpipes/headers to the rear over the axle pipes. Very nice job. It's amazing how small these modern cats are. I think I would go try to find a custom muffler shop that has a good reputation and see what he can do, noting Lees very good point about them keeping it sectional so you can remove it for maintenance if required.
Old Apr 15, 2015 | 02:06 PM
sidescrollin's Avatar
I've always liked the idea of mixing in some e-type when i have to replace my exhaust. I like the look of the stock tips and stuff, but maybe removing the cats and replacing them with 2 high-flow cats, removing the muffler, adding an X-pipe and changing out the rear silencers would be cool.
They supposedly joined the exhaust on the E-type solely for sound. So I always thought doing that and maybe removing all the mufflers in exchange for two borlas would sound nice.
boiler
US Southwest
Dec 20, 2025 12:38 AM
Poet
Feb 7, 2025 02:18 PM
XJ8JR
Oct 2, 2015 12:13 AM
baskervillema
Oct 1, 2015 06:43 PM
