No Blowers working 1996 xjs 4.0
Hello all, I’m currently getting my butt handed to me with a a/c blower problem. I’ve checked all fuses relays and they both work with 12v applied directly. I haven’t found much info on this exact problem. I checked the fuses on the back sides of the fuse boxes (on the wires leaving). I’m leaning toward climate control ecu. Also nothing works in manual. Any ideas would be greatly appreciated.
This is a link to the electrical diagrams for your car.
http://jagrepair.com/images/AutoRepa.../jvs1995en.pdfYou should have constant power on the brown/ white wires at the blower assembies. You should also have grounds at the large black wires.
The blowers use a transistorized circuit for the lower blower speeds, and a relay for the high speed. You will need to check the connections there to see if there are issues. you can find more info in Kirby Palm's "Experience in a Book".
Jon
Jon
delhump
Oct 23, 2012 09:10 AM
