No OBD/diagnostic connection
Old Mar 21, 2015 | 09:31 AM
P.L's Avatar
P.L
Default No OBD/diagnostic connection
Hi all,
I am trying to connect a diagnostic tool to my XJS - without success. The car is a build in 9.1994, AJ16, VIN1967xx. The very same OBD scanner is working fine with another XJS.
The only reaction I get is a blinking LED at the cigarette lighter at each connection attempt.
Any suggestion what can be checked
Old Mar 21, 2015 | 02:53 PM
sidescrollin's Avatar
Don't the OBD1 cars output codes through the computer screen?
Old Mar 21, 2015 | 02:54 PM
What problem are you having with the car anyway?
Old Mar 21, 2015 | 03:29 PM
Vee's Avatar
Vee
I wonder if it would help to swap out the ECU with one from a 96?
Old Mar 21, 2015 | 03:33 PM
Huh?
Isn't a 96 OBDII instead of OBDI? Either way unplugging either would reset the DTCs
Old Mar 21, 2015 | 03:39 PM
P.L's Avatar
P.L
Well, apart from a slightly erratic idle, I guess there is nothing wrong with my car.
However, I got myself one of the Jaguar IDS tools and was just about to play around a bit.
'Check engine' light is off, no DTC to be reported on the trip computer.
Old Mar 22, 2015 | 09:15 AM
Vee's Avatar
Vee
Originally Posted by sidescrollin
Huh?
I thought all the AJ16 engined XJS were OBD2. If the early ones are not, would it become an OBD2 car if you swapped out the ECU for one from an OBD2 compliant car (such as 96) would it then respond to OBd2 tools?
Old Mar 22, 2015 | 09:18 AM
Vee's Avatar
Vee
Do me a favor. Have that IDS plugged in an ready to go. Turn the car off and when you click the software to start reading codes, count to one and then turn the car on. (Not ignition, just the car electronics). Sometimes I can't get it to read the trouble codes unless I turn the car on a second after I've instructed the IDS to check codes,
Old Mar 22, 2015 | 12:07 PM
P.L's Avatar
P.L
All cars with the AJ16 engine are OBD2.
Thanks for your reply Vee! Tried your suggestion several times. Unfortunately without success.
I see the security LED at the cigarette lighter bezel blinking whenever the reader tries to establish a connection. This LED is connected to the security module. I reckon that means there is at least a working electrical connection from the tester to the OBD2-socket and to the security module?
Any other ideas?
Old Mar 23, 2015 | 09:49 AM
Oh I didn't notice that in your sig, my bad.
Anyways, tons of stuff can happen that the computer won't pick up, but I understand wanting to use your new tool.
Is it only unsteady at idle? Maybe check for some vacuum issues, throttle linkage, and IACV?
Old Mar 23, 2015 | 10:37 AM
Vee's Avatar
Vee
The only other suggestion I have is to swap ECUs.
I had your same problem, luckilyI had another ECU so I never troubleshot the problem. That ECU has other issues though. It wasn't reading the O2 sensors correctly, or at least wasn't able to read them flip flopping. I changed the sensors, no change. I changed the ECU and problem went away.
So basically it worked with a third party OBD2 reader, it just never was able to work with my IDS software.
RSpi
Mar 21, 2016 12:02 PM
leep123
Sep 30, 2015 03:41 PM
Rocky15
Sep 28, 2015 04:59 PM
42Ajd
Sep 26, 2015 07:04 PM
