no start problem?
Old Sep 17, 2008 | 08:40 PM
Default RE: no start problem?
Hey one, welcome to the forum
Sorry I cant help but hopefully someone will be along soon who can.
Try sending a pm to ken @ britishparts or Factoryjagtech
Good luck
Jim
Old Sep 20, 2008 | 06:04 PM
jag_genius's Avatar
sounds like starter relay
Old Jan 5, 2013 | 09:49 AM
weecachum's Avatar
I have a 93 Xjs, 6 cyl 4.0. Starter problems too. Can you tell me where the starter relay and or mega fuse is located? Any help would be appreciated
Old Feb 25, 2014 | 01:18 AM
AngelM's Avatar
Weecachum, did you ever find out where the mega fuse is located? I'm also looking for it and I think it's in the trunk in a small fuse box, but I'm not sure. I would appreciate it greatly if you would share it with me. Thanks.
Old Feb 25, 2014 | 08:24 AM
sidescrollin's Avatar
Supposedly the starter relay in a 1993 4.0 is under the hood on the RH side. There is a pack with the horn relay, AC clutch relay, and then the starter relay.
I looked though the wiring diagram and saw nothing about a mega fuse in the circuit
Old Feb 26, 2014 | 12:56 AM
AngelM's Avatar
The mega fuse is in the trunk within three black plastic covers that snap out separately. The cover is marked MEGA FUSE. Starter relay is under the hood in the fuse box on the passenger side and its number F19 and 25 amps. In the cabin there is also another fuse and its number F19 as well and this one is 5 amps and it has various starting functions(ignition relay, ECM, REM, fuel pump relay, start relay).
JarodL
Mar 7, 2024 01:39 AM
jdzubas
Oct 4, 2015 09:14 AM
alpecsa
Sep 7, 2015 11:55 AM
tberg
Sep 7, 2015 07:32 AM
laserguy
Sep 3, 2015 02:02 PM
