OE vs. AfterMarket Crank Position Sensor
Old Sep 11, 2018 | 12:05 PM
JagDE45's Avatar
Default OE vs. AfterMarket Crank Position Sensor
I have gotten some great input from Jagboi64 and others regarding my '94 XJSV12 6.0L Convert. not starting once warmed up.
Has anyone else had a problem with BWD Aftermarket parts such as the Crank Case Position Sensor??? I am getting stories of after market parts not working and searching for OE solving the problem. MY car was fine starting hot or cold when Code FF77 came up requesting a new CPS......Ordered the BWD Part CSS961 from my local Advance Auto Parts and had it installed. The check engine light went out but now she only starts when cold. We have since replaced the fuel pumps, regulator, filters, and strainer to the tune of nearly a thousand dollars having to pull the fuel tank is a big deal. It is feeling stupid just throwing parts at this problem. Looks like I may have no choice but to find an OE sensor and throw more money and parts to my Jag
Have other folks had a problem with these aftermarket CPS's
Old Sep 15, 2018 | 05:57 AM
superchargedtr6's Avatar
Did you replace both crank sensors? As I understand Marelli ignition, the front sensor relates to timing, and the rear is fuel delivery. This is one of those things that I strongly advise folks to replace on the Marelli ignition cars, as these are now 20+ years old.
My first attack on this would be to test for spark when hot. If you have spark, I would think that then it would be fuel related. It could be something as simple as the coolant temp sensor. Maybe check resistance on the coolant temp sensor when cold, then again when hot.
Old Sep 15, 2018 | 08:27 PM
warrjon's Avatar
Marelli Front sensor is TDC for A bank and rear is engine speed.
The sensors are VR and generate an AC voltage with Voltage and frequency directly proportional to how fast the relutctor teeth passes the sensor. Voltage is usually in the order of a few volts not millivolts so I would be surprised if the replacement sensor was the issue, although not impossible. Have you checked the gap if this is too large then the voltage generated could be lower than the Marelli ECU trigger setting.
Marelli engine primary sensors for starting are
the 2 crank sensors front and rear
MAP sensor
Old Sep 16, 2018 | 09:00 AM
JagDE45's Avatar
I am 73 and partially handicapped and unable to wrench the car myself. So, I am coaching a local mechanic ….who is not a Jag expert ….nor am I ...He only replaced the front sensor and tells me he does not know of a gap adjustment on it....can someone explain this gap??
The check engine light went off when new front sensor was installed …...do you think we still need to replace rear sensor and coolant temp sensor.....Are there gap adjustments on them also?
You guys are tremendous ….thanks for the input
Old Sep 17, 2018 | 06:27 AM
warrjon's Avatar
If the gap is too large the sensor will not generate a voltage high enough to trigger in the ECU. The gap should be 0.018"
Old Sep 18, 2018 | 06:33 AM
To "adjust" the gap, the only way I found to do it was to file the mounting boss down a little at a time, then keep checking it with a feeler gauge. The front one is very tricky, as there are three metal "fingers" bolted to the damper. On my cars, those fingers aren't consistent, so I just filed the mounting boss until I got the sensor to .020 on the closest one. On my 89 Marelli car, a shop ran through several thousand dollars, replacing just about everything including the wiring harness. The owner forfeited the car in lieu of payment. I bought it on eBay. Took me 40 hours to diagnose, but the rear crank sensor gap was around .047. I fixed that, and the car started right up.
Old Sep 19, 2018 | 04:04 AM
warrjon's Avatar
With a genuine Jaguar sensor the gap is set, as these are NLA aftermarket units may not be exactly the same causing the larger gaps. My car still has its original sensors and gaps are about 0.020"
Basically you want the sensor as close as possible to the teeth without fear of the sensor tip being knocked off.
Old Mar 25, 2023 | 01:52 PM
gidget's Avatar
Banned
Default Temporary Fix for crankshaft position sensor
If you vehicle crankshaft position sensor get faulty during journey there are some temporary fixes which help you reach a mechanic for replacement. Read Here really helpful
Old Mar 26, 2023 | 11:06 AM
RickE's Avatar
The first time I replaced the CPS on my 4.0 was with an aftermarket CPS that proved to be defective from the factory. The car went from running poorly to no start at all. I bought another replacement and that fixed both problems. Unfortunately, I do not remember where I bought the defective CPS as I had carried it as a spare for quite a while.
cooke
Jun 30, 2018 08:15 PM
hm1
Sep 14, 2012 10:44 AM
Idrivejags
Jul 31, 2012 08:50 AM
Idrivejags
Aug 7, 2011 10:18 PM
Idrivejags
Dec 1, 2008 07:26 PM
