OEM Camcover Gasket VS Aftermarket Gasket
Old May 28, 2018 | 12:32 PM
Vee's Avatar
Vee
Default OEM Camcover Gasket VS Aftermarket Gasket
Would like to mention that the OEM camcover gasket (NBC2525AA) fits way better than the aftermarkets. The spark plug well gaskets (NBC2579AA) seem to fit the same either way, but I would strongly recommend to stay away from aftermarket camcover gaskets...very strongly.
Don't forget to replace the thirteen isolator/seals (NBC2575CA), if you haven't changed them in awhile. I used aftermarket from Rock Auto since the OEM seems ludicrously priced.
And don't forget the TSB on the torque values...
Old May 28, 2018 | 02:40 PM
ronbros's Avatar
No gasket at all, just RTV sealant!
Old May 28, 2018 | 08:28 PM
VancouverXJ6's Avatar
Heretic!
Old May 28, 2018 | 11:08 PM
Daim's Avatar
You are aware that the engine mentioned is not the V12, right? Putting RTV over the AJ6/AJ16 surfaces doesn't make it better...
Vee
Jun 12, 2016 09:00 AM
prodigy215
Aug 27, 2012 06:19 PM
ez53436
Feb 18, 2012 07:11 AM
Iconoclast
General Tech Help
Nov 22, 2010 04:15 PM
