Oil and coolant
Old Dec 25, 2015 | 01:16 PM
Jaguar_libra's Avatar
Default Oil and coolant
Happy days
Just change Oil, New filter drove car for about a Week, I had the car running now for over a year after replacing the ZF transmission. Car has 198000 miles,
Order new coolant hose both upper and Lower. When to flush and replace old hose's. Open the coolant cap. Found Oil mix in, Ahhh I so **** now!!!
Now I need to pull the head off, send to a shop have it check, Replace the Head gasket, along with other Items.
Looking for any pointers and special tools to remove head and Keep the timing chain in place as I service the head.
Any Help at all
Happy Holidays,
Keep driven fast
Old Dec 25, 2015 | 03:32 PM
xjsv12's Avatar
[QUOTE!!!
[/QUOTE]
As I understand, you do have straight six.
Before pull head off, check gasket behind head. It's rear cover six bolts screwed. Before opening, drain coolant.
Old Dec 26, 2015 | 12:13 AM
Also see my answer in the "General Tech Section", for your other post on the same issue.
Old Dec 27, 2015 | 01:38 PM
Yes I do have a 1995 XJS AJ16 motor, With a ZF 4 speed transmission. did check transmission and power steering fluid, No sign of water: Oil dipstick, Transmission dip stick or power steering.
Any special tools or trick's on pulling head off an timing chain in place???
To Be honest driving the cat is fun and very fast, Now I need to bring inside and once more do repair work. Most of my ASE friends that how the Jaguar tail wag, so I need to trouble shoot the issue's an repair. Its winter time now, spending the working, and not playing
RickyJay52
Dec 25, 2019 11:56 AM
RobbyHughes
Mar 8, 2016 07:46 AM
Jennifer S Flavell
Feb 5, 2016 04:03 PM
InverStype
Dec 24, 2015 07:56 PM
Pirate
Dec 24, 2015 04:44 PM
