old geoff in England
Old May 26, 2022 | 10:20 AM
old geoff's Avatar
Thumbs up old geoff in England
xjs v12 5.3 1990, how does one adjust idle speed (slow it down slightly)
Old May 26, 2022 | 10:53 AM
Geoff,
I've moved your question from General Tech Help to XJS forum. Members with the same model are more likely to see it here.
Old May 26, 2022 | 11:16 AM
jal1234's Avatar
Look at page 33 of the document below. You adjust the Auxiliary air valve (AAV) to adjust idle speed. The document is for the Lucas distributor variant, you have Marelli, but all of the throttle adjustments and idle speed adjustments in the document apply.
http://jagrepair.com/images/AutoRepa...XJS%201992.pdf
Old May 26, 2022 | 11:45 AM
Greg in France's Avatar
You are looking for this item, which is at the cabin end of the B bank of the engine (UK passenger side), just lower than the inlet manifold itself. Turn the bolt inwards to reduce the idle speed.
This pic is shot with the inlet manifolds off.
Old May 26, 2022 | 12:08 PM
Brake buster's Avatar
as a caveat,
ensure both TB's are set to 2 thou , and no tightness in the linkage, and ensure the pivot bushes are in good condition before adjusting the idle at the AAV , which should only be done for ' hot idle' as cold idle will see it around the 1200 revs for a few minutes, which is what its there for
BB
svocal
Jun 18, 2022 11:41 PM
sd63141
Jun 28, 2021 09:06 PM
gccch
XJ40 ( XJ81 )
Dec 26, 2018 08:08 PM
88-xjsv12
May 3, 2014 12:20 AM
Qgregg
May 3, 2012 06:37 PM
