Parking brake adjustment mystery
Old Dec 22, 2025 | 05:17 AM
meh's Avatar
meh
Originally Posted by ptjs1
In the UK, the "Handbrake" or "Parking" brake has never been regarded or referred to as an "Emergency" brake, certainly not since the 1960s when the introduction of dual-circuit hydraulic brakes significantly improved braking efficiency and reliability. As far as I'm aware, the car literature doesn't refer to these brakes as "Emergency" brakes? I think that must be a US nomenclature?
In the UK, the standard applicable to the annual MoT test is to hold the car on a 1in 6 slope (16%). My late facelift car uses the drum-in-disc setup which is perhaps more efficient. However, I never use the handbrake on any car I own to hold the car in place when parked. I've always put Manual cars in 1st or Reverse gear, and Auto cars in Park. I admit that I do operate the handbrake almost every time I use the car, but that's merely to trigger the light so that I can fold the roof down!
When I recommission my 1979 pre-HE, no doubt I'll have a quick look at the handbrake setup, and I'll even submit it for an MoT test, even though it's now MoT exempt.
Paul
The e.u. exempts nothing here, the much cars they can discard to the junkyard, the better, they all became electro tards.
Now you're right no one use the handbrake but sometimes it can be usefull.
Back to the xj-s, really they could have used wooden pads, it would gave the same result, it's not at the level of what jaguar is supposed to be.
Old Dec 22, 2025 | 05:20 AM
meh's Avatar
meh
Paul
Lol
Lol
Old Dec 22, 2025 | 06:42 AM
Greg in France's Avatar
The handbrake pads give over 5 square inches of friction surface. This is plenty to hold a car on a 1 in 6 slope; though larger pads are always a good idea.
The problems with the Jaguar inboard setup are that:
  • the pads now available are not sufficiently strongly bonded to their backing plates
  • the pads need very careful setting up to ensure all the friction surface is applied to the disc
  • the cable and self adjusters need very careful setting up
  • rolling road MOT/Controle Technique handbrake tests put far greater strain on the handbrake system than a static 1 in 6 slope test does.
I have repeated this many times and posted a "how to" equally frequently; but it remains true:
The handbrake can be made extremely efficient and very durable, if an owner is prepared to spend a little time doing the necessary work. I fixed mine over 10 years ago and have not had to touch it since; it has passed multiple rolling road MoT/CT tests with no problems, and will hold the car against the gearbox in drive at 1500 rpm.
Old Dec 22, 2025 | 11:23 AM
meh's Avatar
meh
Lol, again one brilliant design where no tool can cut that bolts, nor remove the soldered nuts on the exhaust collar, delicious as a mint boiled chicken 😂👌
Any worst option has been chosed to build this thing.
Now what, i have to cut the exhaust silencers to free the IRS ?
Of course, what else ?
Changing handbrake pads require new exhaust line, new bushings, new anything you'll touch anyway as it's a disaster on wheels.
Old Dec 22, 2025 | 12:34 PM
Those nuts on the exhaust look to have been welded. If so, that is not a Jaguar OEM fitment; a previous owner has done it.
Old Dec 22, 2025 | 12:51 PM
meh's Avatar
meh
Yes or maybe walker used to deliver it's exhausts with welded nuts who knows.
This is just disgusting lol. I would cut all this but then it would require new exhaust, what a nightmare for fürking handbrake pads.
What on earth did they need to copy silly ideas from Alfasud.
If i could i would add discs rotors and serious calipers instead of fighting against this dumb system. I leave this for the night, tomorrow is a new day.
Old Dec 22, 2025 | 12:52 PM
meh's Avatar
meh
Old Dec 22, 2025 | 04:41 PM
  #28
Jagboi64's Avatar
The nuts were never welded from the factory, someone has been in there. I would use a cutoff wheel on a die grinder to cut the bolts. Then you can get the pipes out and deal with the nuts on a workbench.
Old Dec 22, 2025 | 09:14 PM
meh's Avatar
meh
I attempted this as well but angles are very smart designed, if you want to insert grinder wheel and cut bolts, then have to choose which other part near exhaust pipe you would alterate or destroy. Maybe a sort of flexible with a cut wheel but this would take ages. Fascinating how it looks easy to do on pictures but finally not easy at all and time consuming.
Old Dec 22, 2025 | 09:45 PM
  #30
meh's Avatar
meh
It's 4:40 in the morning here but at 8:30 i'll try with electric impact hammer i have, it's made to cut stones and concrete, it should be able to destroy the bolts.
Old Dec 22, 2025 | 11:15 PM
  #31
Jagboi64's Avatar
I've cut them in the junkyard with a reciprocating saw without any trouble.
Old Dec 23, 2025 | 09:13 AM
  #32
meh's Avatar
meh
Looks like it will be good with this thing, some reinforced grinder.
Old Dec 23, 2025 | 09:14 AM
  #33
meh's Avatar
meh
Old Dec 23, 2025 | 11:31 AM
  #34
meh's Avatar
meh
Finally got rid of these terrible soldered nuts and rusty bolts. It looks like walker exhausts are delivered with soldered nuts, they were too factory look to have been made by some sunday's mechanic like me.
Old Jan 19, 2026 | 04:38 AM
  #35
meh's Avatar
meh
Excessive lifting the body is not that much usefull.
I pulled the irs on the side, slided it on reinforced platforms on wheels.
Old Jan 19, 2026 | 04:44 AM
  #36
meh's Avatar
meh
So this is supposed to brake 🫤
Old Jan 19, 2026 | 04:48 AM
  #37
meh's Avatar
meh
Slide the irs at reasonnable body height
Old Jan 19, 2026 | 04:53 AM
  #38
meh's Avatar
meh
Lol, Like if glue could keep pads affixed properly 🤪
News parts are still the same, with same weakness. Impressive engineering lol
Why not have used rivets through metal tiny cylinders to add extra strenght to tearing like these used on clutch, simple.
jagophile
Aug 18, 2020 05:54 AM
Atco
Mar 14, 2019 07:08 PM
Adam Lueb
May 3, 2016 07:56 PM
kentmcnorton
Jan 17, 2016 07:49 AM
Roman K
Jan 29, 2013 05:13 AM
