Part bcc5579
Old Dec 23, 2020 | 01:31 PM
Rick25's Avatar
Originally Posted by malc4d
Jeeezzzz l'm still looking for this part.....twice now I've waited for it to come through the door only to find that is part 5578 again (even though its clearly marked as such on the bag...!!!).
Try info@jagxjsparts.com
LeRoy should be able to get you squared away.
Old Dec 23, 2020 | 02:13 PM
Mac Allan's Avatar
I ordered the Aston parts from Scuderia, and they look like the Jaguar parts but they seem to be of a harder less flexible material.
Any hints on how to install them without breaking?
Old Dec 23, 2020 | 06:29 PM
ptjs1's Avatar
Mac Allan,
I had two of the last JAguar-supplied ones and they were also very hard. I soaked them in hot water and then they pushed in easier.
Good luck
Paul
Old Dec 23, 2020 | 06:45 PM
Mac Allan's Avatar
Originally Posted by ptjs1
Mac Allan,
Good luck
Paul
Paul,
If by any chance you have a photo of them properly installed as a reference for me, I'd much appreciate it if you could post it. I want to make sure I install them with the correct orientation.
Thanks!
Old Dec 23, 2020 | 07:12 PM
ptjs1's Avatar
Mac Allan,
Happy to do that but cant get down to the car until 27th earliest.
Paul
Old Dec 26, 2020 | 10:38 AM
Robbo D's Avatar
I have just fitted 2 of these from Aston Workshop Parts here in the UK. Fitted perfectly. Part no for the LH 83-123811-BA. RH is 83-123810-BA. £4.36 +VAT each.
https://www.astonparts.com/
Rob.
Old Dec 26, 2020 | 12:12 PM
ptjs1's Avatar
Mac Allan,
I wanted to go and roll the wheels forward on the XJSs this morning as they've been sitting for a few months, so I got a few pics of the roof locating pin cups.
You should be able to see the orientation of the offset on the rubber cups. The one on the right hand side of the car shows the positioning the best.
Let me know if you need any more pics.
Paul
Old Dec 26, 2020 | 03:23 PM
  #28
Mac Allan's Avatar
Mac Allan,
Paul
Thanks! That's perfect and much appreciated.
Old Dec 27, 2020 | 09:20 AM
jnporcello's Avatar
Yes, thank you so much from me as well. Mine should be here from Scuderia Tuesday!
Old Apr 11, 2021 | 02:57 PM
  #30
jnporcello's Avatar
Holy cow, I have soaked them it hot water, softened with a heat gun and I just can't get them pressed in. Any tips. These are the Aston Martin ones and may be a little harder from what the post says
Old Apr 12, 2021 | 11:19 AM
  #31
Mac Allan's Avatar
After warming, I used the round end of a ball peen hammer to tap them in.
Old Apr 12, 2021 | 02:39 PM
  #32
ptjs1's Avatar
jnporcello,
Knowing how a little about AM operated re. the Jaguar-derived parts for the DB7, I would guess they came from the same OEM supplier of the Jaguar part. It wouldn't make sense for AM to get these parts produced elsewhere.
I found that the trick was to carefully push down the bottom seat of the insert to pull the whole thing in without distorting the top part. Just be careful not to split it as you push it in. As Mac says, try and use something round that fits the profile of the bottom of the insert.
Good luck
Paul
Old Apr 13, 2021 | 06:06 AM
  #33
jnporcello's Avatar
Thanks guys. What worked for me was a heat gun to soften them and then the round end of a screw driver to push down while I used a flat end screw driver to try to push the tabs in. Thanks for all your help and advice.
Old Apr 17, 2022 | 08:35 PM
  #34
Deltaflash's Avatar
Default THANK YOU!!!
Just wanted to say thanks to all, for ALL of the information on this thread. This is an amazing forum. I have been looking for these grommets for 2 weeks solid. I am hoping the wind noise is cut down when installed. I saw mine coming apart and they literally crumbled when I touched them. Once they were out the wind noise went up about 10x. We will see...
Andreas Schmieg
Feb 11, 2018 12:14 PM
mhamilton
General Tech Help
22
Jun 7, 2016 02:02 PM
malc4d
Jul 25, 2015 03:05 PM
buddyluv
Jun 23, 2012 08:18 AM
wradford
Oct 31, 2010 05:29 PM
