Passenger door foot dome light will not turn off
Old Sep 1, 2016 | 09:51 PM
Michellehmcclure's Avatar
Default Passenger door foot dome light will not turn off
I have a 91 xjs and the light on the passenger side door turned on and won't turn off. Any idea what is wrong?
Old Sep 2, 2016 | 02:42 AM
malc4d's Avatar
Have you a switch on the dash ?
Old Sep 2, 2016 | 05:52 AM
Paul_59's Avatar
Banned
Door light switch contacts can be cleaned with contact cleaner spray or fine Emery paper
If you mean this light it's controlled by a switch at the front of the door.
When the door closes it pushes the switch in, switching light off.
Sometimes a sticking switch can be rectified by pushing switch in and out with your hand.
Old Sep 2, 2016 | 05:58 PM
warrjon's Avatar
Both door lights are commoned so either door switch will switch on both lights.
The lights are switched on by the switch shorting the Purple/White wire to ground. If this wire was shorted both lights should be on.
If you pull the light out of the door check the P/W wire it may be broken, or the terminal pulled out of the plug and shorting to the door frame.
altownsend
Jan 20, 2018 10:43 AM
andy.buxtonxf
Apr 21, 2016 11:44 AM
Michael Wittmann
Mar 29, 2016 05:16 PM
Michael Wittmann
Mar 27, 2016 07:45 PM
Nov 5, 2006 12:00 PM
