Passenger Door Window
Old Apr 18, 2017 | 05:36 AM
Brass Boy's Avatar
Default Passenger Door Window
I have a late 1989 Jaguar XJS. The passenger door window does not work, I've replaced the switch on the centre console but this has not resolved the problem, any ideas please?
Old Apr 18, 2017 | 05:39 AM
warrjon's Avatar
Pull the door card off and measure voltage on each wire to the motor. You should have 12 volts on BOTH wires, when the switch is pressed it grounds one side of the motor and the window moves.
Old Apr 23, 2017 | 07:45 PM
kenatofc's Avatar
If you have a 12V electrical source (if not I would suggest buying one since you have a Jag) take the door panel off and inspect the rails the glass slides up and down on. Then disconnect the motor and hook the leads up to the 12V and see if it goes up and down, is binding or no motor sounds... You should be able to isolate the problem pretty quickly.
Ken in WV
Old Apr 24, 2017 | 10:38 AM
kenatofc's Avatar
did not spell out ! disconnect the motor by unplugging the two wires to the motor and place your 12v source to the motor, it should go up or down. reverse the wires and it should go the other way. if you hear the motor sound but no movement, you may have a stuck gear or a binding window. let me know what you find and we can discuss the next move which would be to adjust the window rails or remove the window motor and mechanism from the door. Ken
Old Apr 25, 2017 | 02:38 AM
Hoppy's Avatar
I had the same issue with my drivers side RHS window. pulled the door card off. The window tracks fine. I had 12v at the motor. so I gave the motor a smack and away it went. So put it back together, worked for a little while, Then i found I had to slam the door whilst holding the switch down to get it to work.. This gets awkward on the freeway (esp with the Handbrake - sorry I mean wife in the car). I'm really gonna have to fix it proper so Im watching with interest. good luck!
rickead2000
Nov 28, 2018 12:42 PM
graham11
Oct 19, 2016 12:31 PM
hirev
Oct 16, 2016 08:49 PM
dlpfrench
Oct 9, 2016 10:11 AM
Dec 24, 2006 08:59 PM
