Passenger window/door seal damaged
Old Aug 17, 2018 | 04:27 PM
Kariblay's Avatar
Default Passenger window/door seal damaged
Does someone have a how-to to replace these?
thank you.
Old Aug 18, 2018 | 07:54 AM
Doug's Avatar
Google "Jaguar BD464401"
Old Aug 18, 2018 | 09:34 AM
Kariblay's Avatar
Thanks..I ordered 2 from JagBits. Do I need to remove the door panels to remove the old and install the new seals?
Old Aug 18, 2018 | 11:40 AM
J_C_R's Avatar
I can't tell what part you are specifing in your photo. But, if it's the seals that go on the body around the door entry, no, you don't have to take anything off other than the old seals.
Putting the new seal on is tedious at first, but if you have some sort of a plastic tool that won't dig into the door seal material, that will help.
Removing the old seal is easy, just grab it and pull.
I replaced mine about 3 months ago...job is 90 minutes tops at a leisurely pace.
Thanks,
John
1987 XJ-S V12
70,000 miles
Old Aug 18, 2018 | 11:42 AM
J_C_R's Avatar
I should (maybe) correct myself.
I see that you have a convertible, I have a coupe, so my information my be irrelevant.
Thanks,
John
Old Aug 18, 2018 | 11:55 AM
Kariblay's Avatar
[QUOTE=J_C_R;1948596]I can't tell what part you are specifing in your photo. But, if it's the seals that go on the body around the door entry, no, you don't have to take anything off other than the old seals.
Yes...it is the seal that protects water from getting down into the door and it “wipes” water off as you put the in down down.
Salu498
Feb 3, 2018 10:35 AM
XJsc-guy
May 23, 2017 02:46 PM
Anthony8858
Jul 30, 2016 10:07 AM
matl
Sep 11, 2008 12:30 AM
matl
Jul 16, 2008 12:12 PM
