Patient A/C Coaching Needed
Old Apr 7, 2016 | 09:50 PM
  #41
JTsmks's Avatar
Yes, when I did my rebuild I ditched the cruise control and all associated loom and bits. V access and plug changes are much easier now. Incidentally, the Sanden is smaller in diameter than the old OEM A6 Harrison, so changing plugs A1 and B1 is considerably easier. Greg
Greg how is the cruise bellows in the way for plug changes or V access? It takes seconds to remove the couple bolts and take it out of the way. Sorry I don't see removing it as a "bonus" in the access/room department. I much prefer it's use when highway driving and never found it difficult to move when needed.
Old Apr 8, 2016 | 01:37 AM
  #42
Greg in France's Avatar
Ok with me, just my view.
Greg
Old Apr 8, 2016 | 01:40 AM
  #43
Originally Posted by Mac Allan
How did you deal with the High Side Low Pressure Switch? I can't see one on the schematic of the Sanden U4646, did you add one, or eliminate it, and just wire the clutch to ground?
As far as I know, mine never had one separately from the compressor. Maybe there is something incorporate into the compressor that handles it? I have nothing external.
Greg
Old Apr 24, 2016 | 01:07 PM
  #44
Mac Allan's Avatar
Greg or Anyone with a Sanden conversion, how is the compressor secured to the engine block on the back side?
Was a new bracket fabricated? Is there an off the shelf solution? Thanks.
Old Apr 25, 2016 | 01:11 AM
  #45
I did not actually fit the Sanden, Mac, as it was done years back before I retired. But at the back the Sanden has two lugs cast into the ally body, and these just bolt up to the bracket, which is a wide U shape (the verticals of the U fore and aft). The bracket was the basically the same as the OEM Harrison compressor used, if not, then only the rear upright of the U maybe cut and repositioned. Nothing major. Once you get the Harrison off, and have the Sanden in your hand, it will be obvious what needs to be done.
Greg
seawind
Mar 25, 2016 09:58 AM
veeracer
E type ( XK-E )
Mar 3, 2016 02:28 PM
John Gloyd
Feb 26, 2016 01:03 PM
brantman
Feb 25, 2016 06:17 PM
xjtom
Feb 23, 2016 09:23 PM
