Is this the power steering fluid cap?
Old Sep 24, 2017 | 01:29 PM
Grandpa'sXJS's Avatar
Default Is this the power steering fluid cap?
Sorry for a remedial question: is this the power steering fluid cap on my '84 XJS? I've just inherited this car and am obviously learning the basics, and enjoying the learning so far. I can't find a good fluid-location diagram online, it's not in the manual, and the cap isn't labeled.
I have some smoke that seems to be coming off the cat, and a fluid leak. Others on this forum seem to think it's a power steering fluid leak. I did take a look, and this thing is indeed bone dry, so it would confirm suspicions. Before I add anything, can someone please confirm this is the power steering? If so, are there common leak sources? It was topped-off when I had an oil change, 500 miles ago, so a pretty fast leak. Also there's a new groan when I turn the wheel. Dexron II or III have been recommended - particular brands recommended or whatever AutoZone has?
Thanks a lot in advance for the help.
Old Sep 24, 2017 | 01:39 PM
Daim's Avatar
Yes, that is the PAS pump with cap above it.
Old Sep 24, 2017 | 01:40 PM
Daim's Avatar
All the hoses perish and leak in the end... Just replace the lot. There is a total of 3 hoses. 2 have some steel piping and rubber sections... One is just pure rubber.
Old Sep 24, 2017 | 01:45 PM
Great, thanks @Daim. Will do.
Dexron II or III okay to use?
Old Sep 24, 2017 | 01:55 PM
Doug's Avatar
Dex II or III is fine
Common leaks are the hoses and the steering rack itself. Often both the hose AND the rack.
Old Sep 24, 2017 | 08:53 PM
Perfect - thanks @Daim and @Doug. I appreciate it.
