Power Steering fluid in the Cooling system?
Old Mar 15, 2012 | 07:52 PM
rougeedition's Avatar
Default Power Steering fluid in the Cooling system?
Hi there,
A few months ago, on my '89 XJS 12cyl 5.3L Rouge, my power steering went out, and have been out of country so hadn't had a chance to get it fixed yet. Just recently, I filled it with fluid and noticed that the water was lee king into the power steering form the radiator. And visa versa. As if it is all one system. Anyone have any ideas on what is going on?
Thanks,
Chris
Old Mar 15, 2012 | 09:18 PM
Doug's Avatar
I can't think of any place where the power steering and cooling sytems come together.
There is a *transmission* cooler inside the radiator and, if it leaks, the trans fluid and radiator coolant can mix. A bit rare but it does happen.
Old Feb 11, 2013 | 02:21 PM
lber1568's Avatar
Default Steering fluid/cooling fluid mixed
I have a 1996 XJ6 with 90,000 miles. While driving today I heard a strange noise like a humming sound. When I got off freeway and turned into gas station the power steering was very hard to turn. When opening hood, I had steering fluid pumping out of the fluid holding tank. After it stopped pumping out, I opened lid on tank and everything was foamy looking. I then checked cooling tank overflow tank and it has power steering fluid in it. Mechanic caid I needed to tak it to Jag dealer. While driving to dealer it overheated so I shut it down and towed it back home (Closer than dealer).
I noticed that steering fluid line goes through radiator before going back to pump. First time I noticed also that it looks like engine driven power steering pump (No belt)
My guess is the radiator has developed a leak between cooling and power steering cooling portion. I didn't checl transmission fluid for issues.
Anyone had this problem? HELP!!!!!
Forcedair1
Sep 8, 2025 01:57 PM
mbergen
Oct 23, 2019 10:26 PM
PMKimpton
Aug 3, 2019 08:22 PM
Jjscruggs1
Aug 2, 2017 04:40 PM
sogood
Sep 15, 2015 07:35 AM
