Power steering rack rebuild 1996 XJS
Old Apr 17, 2019 | 07:24 PM
Softball60's Avatar
Default Power steering rack rebuild 1996 XJS
I have noticed a small amount of steering fluid on the ground after parking for a while.
Looks like a rebuild or purchase of a rebuilt unit may be in order. I’m still pretty handy with repairing my car. I’ve had my cat for ~ 5 yrs. and to date no mechanic has touched my car.
I feel I can rebuild and replace seals as required. The price for a seal kit is ~$130. A replacement rack is ~$250 with $100 core charge refund.
How difficult is the repair?
Appreciate your comments
Softball60/Paul
Old Apr 17, 2019 | 08:00 PM
EcbJag's Avatar
Can't speak to the difficulty to rebuild but if for $20 more you get a rebuilt part with a warranty on it then that seems like a pretty good deal compared to the price of the seal kit.
Old Apr 18, 2019 | 01:34 PM
NJ2003XJ8's Avatar
Check for you seal kit here https://www.motorcarsltd.com
Now, where did you find " A replacement rack is ~$250 with $100 core charge refund."
Old Apr 18, 2019 | 06:01 PM
Softball60's Avatar
Steering gear super store $229.95, Detroit Axle $260 and a couple more.
A couple of the units listed stated specifically 1996, 2+2
My only question is what’s with or w/o servotronics 3 bolts or 4 bolts
Softball60/Paul
Old Apr 18, 2019 | 06:29 PM
warrjon's Avatar
I would pay the $300 for rebuilt rack, you get a warranty.
I rebuilt my rack and when I put the piston back in I must have nicked the seal with the teeth on the rack ( and yes I taped the teeth and was very careful) I ended up giving the rack to a professional $500 for the rebuild here in OZ.
Old Apr 19, 2019 | 02:07 PM
ptjs1's Avatar
Paul,
It may be that you've got a leaking rack, but if that is only based on seeing some ATF fluid on the ground, I would suggest you do much more investigation before committing to seal kits or even a new rack.
There are a number of other reasons that could be the cause of leaking ATF including:
- the joint of the pipes to the PAS reservoir
- the joint of the pipe at the PAS pump
- the joint of the pipe at the steering rack
- the transfer pipes on the steering rack
- the joints of the Autobox oil cooler pipes at the Autobox
- the joints of the Autobox oil cooler pipes at the cooler rad
It's worth looking at all of these first to try and pinpoint the cause of the leak.
Good luck
Paul
Old Apr 19, 2019 | 02:38 PM
Softball60's Avatar
Sorry I didn’tmake it more clear in the original post that it is leaking at the plastic boot cover on the tie rod drivers side.
Thanks and sorry!!
Softball6060/Paul
Jagfix38
XJ40 ( XJ81 )
80
Feb 24, 2025 08:14 AM
mkinn
Jun 25, 2019 12:24 PM
Drb007
Apr 21, 2014 06:26 PM
2000ViperGTS
Jan 2, 2014 02:56 PM
Capt.n Bob
Oct 8, 2013 12:13 PM
