power window relay
Old Jun 25, 2015 | 01:12 PM
reichstall's Avatar
Default power window relay
anyone know the color of the relay for power window, I think I found it is it white so damn hard to find stuff on these cars even with chart I think they just put it where ever they felt like.
Old Jun 27, 2015 | 03:13 PM
Stargazer XJS's Avatar
It may be dependent on the year, but your power windows might be routed through some kind of thermal lockout switch and a circuit breaker. These can be found (in LHD cars at least) to the right of the passenger's side circuit panel under the glove box. You'll have to take off the panel under the box to take in the madness in its entirety.
Old Jun 28, 2015 | 01:41 AM
Greg in France's Avatar
Please add your model, engine size and year of manufacture to your signature. Then we can help.
Greg
Old Jun 28, 2015 | 01:28 PM
reichstall's Avatar
Default relay
OK so I got it mine is white the thermal cut out is black tested all this tested the switch only to find out i have a ground problem and possibly two weak motor they will work by manually making a ground but not to good.this project really shows that jaguar has way to many relays and stuff laying around the system could have been so simple by the way it is an 88 xjs lhd.now to find the bad ground.
Old Jun 29, 2015 | 08:33 AM
RagJag's Avatar
I feel your pain. The XJS could have been made without so many modules and relays to do things that we had been doing for so long without them. Unnecessary electronic and vacuum controls are one reason the XJS is so low priced on the used market.
RagJag
99xk8guy
Sep 29, 2025 10:51 PM
99xk8guy
May 28, 2024 09:36 PM
CaneCounsel007
Nov 13, 2015 09:05 PM
abonano
25
Sep 25, 2015 10:43 AM
tonyforman
Sep 10, 2015 07:23 PM
