Power Windows on an 84
Old Jan 9, 2010 | 06:53 PM
jfrog's Avatar
Default Power Windows on an 84
So, my drivers side window decided to not go back up after it went down. I decided to see what was going on and found that the window motor is only turning one way. Is this normal? Should'nt the motor be spinning both ways? If so, does this mean I need a new motor?
Thanks!
Old Jan 9, 2010 | 07:30 PM
Doug's Avatar
More common is a problem with the window switch. If you are good with your hands you can carefully pry it open and clean the contacts. Quite often that's all that's needed.
Old Jan 10, 2010 | 11:25 AM
jfrog's Avatar
Interesting, thanks Doug. I'll go ahead and see if that works.
Old Jan 10, 2010 | 04:29 PM
BlackJack's Avatar
I agree about the switches. Sometimes they respond to a squirt of electronic cleaner / lubricant from their topside. Just use the provided extension tube on the spray can and a rag around, to prevent blasting the whole interior.
Old Jan 10, 2010 | 06:31 PM
jfrog's Avatar
Hey guys, that was the problem. I simply disconnected the male and female connections of the switch, wiped off the male prongs and blew air into the female end. Both windows work and are good to go.
Thanks again for all the help!!!
Old Feb 11, 2011 | 07:02 AM
BmoreDuke's Avatar
New guy here. I have an 89 XJ-S and experienced a similar problem with my driver's side window this morning. My window will go down but not up. How do I get to the contacts to clean them and what type of cleaner should I use?
Thanks for your help.
Old Feb 11, 2011 | 09:28 AM
Doug's Avatar
Use aerosol electrical contact cleaner. You local auto parts store will have some.
It's been quite a long time since I removed an window switch from an XJS. As I recall the *correct* way is to lift the ski slope (console woodgrain panel) so the switch can be released and pushed out from behind. However, I also have a vague memory of siply being able to wriggle the switch out from topside.
Others will chime in.
Old Feb 11, 2011 | 04:38 PM
matjohns's Avatar
Mine pop out with a razor blade slid under the edge of the switch, and some wiggling, but there's only two or three screws holding the console in place, so It's not hard to pop it up to get to the switch from the under side.
Old Feb 11, 2011 | 07:10 PM
BmoreDuke's Avatar
Thanks for the advice. I'll give it a shot this weekend. It was a cold ride home. Love the ride, though.
Old Feb 12, 2011 | 08:05 AM
BmoreDuke's Avatar
The spray did the trick. The switch popped right up with a small pull. I'm guessing it had been pulled before. Thanks for the advice.
Old Feb 17, 2011 | 09:15 PM
nosox's Avatar
FWIW mine quit in the down position,after cleaning, spraying and lubing, it still didn't want to move. In frustration i gave the top of the motor a short sharp rap with a hammer, and 3 yrs later, no problems.
99xk8guy
Sep 29, 2025 10:51 PM
99xk8guy
May 28, 2024 09:36 PM
GordoCatCar
Jan 2, 2017 01:10 PM
1964Daimler
Sep 9, 2015 11:28 AM
