Radiator Caps
Old Jan 4, 2021 | 12:56 PM
Robbo D's Avatar
Default Radiator Caps
Hi all. A bit of advice if you please. I want to replace both coolant caps. I hope to use a solid cap on the centre fill point and a 16psi on the expansion tank. Will the EAC3424 be ok for the centre fill or if not advice on an alternative would be much appreciated.
Rob.
Old Jan 4, 2021 | 07:42 PM
Not sure of the OE spec, never used them.
I dropped ALL my V12 cars, Series 6cyl cars to 13psi and used CPC caps.
I have even dropped the 2 S Type X200, and the X Type X400, to a lower KPA cap.
ZERO issues wiith any of them.
I have that spec/number somewhere in the stash in the shed, and sill go looking later in our day.
Found it, CPC 543/13.
Old Jan 5, 2021 | 02:16 AM
Greg in France's Avatar
Rob.
You can get solid caps for the spout from Car Builder Solutions. I used these for some years before eliminating the spout!
Old Jan 5, 2021 | 08:33 AM
Robbo D's Avatar
Thanks for your replies. I have ordered the EAC3424 and also a CCC6707 for the expansion tank from David Manners. The caps Grant mentioned only seem to be available in Australia.
Rob.
Harry Peter Rose
Feb 15, 2018 05:46 PM
INDYJAG-84
May 8, 2017 02:31 PM
jaguarmarkv
Mark V - X 420G
Jun 16, 2016 09:21 PM
Adam Lueb
Jan 28, 2011 01:12 PM
