Rear cage removal
Wandering a bit off topic, again...
Yes, the C3 dash is a PITA. I cursed those engineers out also, but at least i was able to sit in the seat while working on it, and not be under the car or bent over something.
Back to the XJS, Yes, the interior ride is superb, and quiet. I am amazed at how little road/tire noise there is in the drivers seat. My '16 Z06 is MUCH louder inside, I am sure tires have something to with it, but the C7 is loud inside, diff pavements have drastically different loudness. The Z06 is running 8 YO factory Mich PSS run flats, the XJS has new V rated Cooper CS 5 tires.
Doug
Doug
Since I’ve done a lot of both I’m sure this is true. Jaguar even has a bracket so you can slide the sprockets forward out of the way without losing tension on the timing chain.
In addition when finished no need to reset the timing. The distributor remains in place on the V12. As does the accessory’s, harmonic damper, water pump, front timing cover, timing chains, and sprockets.
Instead of sliding the cam out of the block, with Jaguar, you simply lift them off the top of the engine.
Finally because the springs don’t have to fight the weight of the lifter, pushrods, rocker arms, that a Chevy does. As long as the oil is properly changed the V12 may go its whole life without need of replacement or adjustment the way the Chevy does.
Doug
Doug
I mention this because, yes, some tasks are easier on the Corvette. But there are also trade offs. The dash of a C4 ( which I owned ) is lucky to get out of the warranty period before it fails.
Others issues like the hybrid oil system failing with regularity on higher powered Corvettes,
The nightmare of changing the clutch on newer Corvettes, Etc.
No car is perfect.
Back to the topic at hand.
You'll notice in one of the pictures that he has the car up on jack stands at all four corners. This is HIGHLY recommended as opposed to just raising the rear end.
Numerous advantages: a) Ease of disassembly and removal of cage; b) ease of sliding cage out either from the rear or a side; c) far easier to reinstall and reconnect on a level plane; d) prevents possible damage to front lower air dam.
This is true, Brad, but I recommend the front lower suspension wishbone being on blocks or the wheels in indents in wood cribs. It is surprisingly easy to accidentally pull a car off four jackstands when - for instance - straining at a brake caliper bolt or an output shaft nut.
Blocks....good ones..... are safer than jack stands.
Yes, I concur completely. Some 4" x 4" x 8-10" blocks screwed together 2 or 3 layers high can provide excellent safety precautions.
There are no second chances if a two ton car falls on you. As we said in the Army, "Have a backup to the backup."
themon
Jul 21, 2017 10:15 PM
